flyinbrick68
- Joined
- Mar 22, 2013
- Messages
- 256
- Reaction score
- 48
My destop dyno puts out a figure of my 451 at 480 hp 4750rpm and 601 ft lb. of torque at 3000 rpm. I think its way optimistic but that's using 9.7:1 compression with 2.08 intake 1.81 exhaust valves 224 intake 234 exhaust duration .518 lift intake .543 lift exhaust on a 110lsa advanced 4 degrees. 850cfm carb 1" spacer and timing at 36 degrees with a dual plane exhaust. I loaded a flow file for the heads which I hope I can achieve with porting my 346's that tops out a 255cfm at .600 lift. So to put it the best I can I think the software which is the virtual engine 2000 is way optimistic. I don't think they hold much water.
