Ok this weekend I roll the 66 parts car on to my drive way. Got the front tore off the 65 and 66. Switched doors from 66 to 65. Got them aligned on the 65 they open and shut beautifully. Got to looking at both sub (stub) frames and realized the 65 was hit hard once and was repaired but will need some more repair work (welding and smoothing). So are the sub frames the same from both years? 65 is 383, 66 is 318 poly. So I know motor mount are different. The frame on the 65 is not out of wack to bad but would you guys switch them if it was you? And is the poly worth any thing? It turns by socket and break over bar. I have a guy that wants it he offered $175. Before we knew it would turn over.
So a recap.
Are the frames the same?
would you switch them if it was you?
Is that a good price for the poly?
So a recap.
