Heavy Metal
The flying wing aircraft requires constant adjustment of the control surfaces. I find it amazing that the YB-35 and YB-49 flew with mechanical or manual (pilot) controls.
i think I recall the flying vings were hard to fly in the pure analog era. I learned the Conccorde was "tailess." Part of why its had a "droop nose" was so pilots could see better but also inherent to the design they had to do it. it had a vertical stablizer but no horizontal stabilzers, opting instead for sophisticated contrlols on specially-curved delta wings. Even then it was allegedly hard to fly.
Below, the Horten-229 in the 30's (a tad ahead of usa & Northrup B-35 ) alllegedly was the first to try "tailess", essentially a flying wing. Like many things the Nazis were technicallly ahead of the world on, they couldn't finish it and never used it in WWII.
https://en.wikipedia.org/wiki/Horten_H.V
View attachment 750606View attachment 750607
There’s a HO 229 at the Smithsonian and I believe that they are restoring it.
Horten Ho 229 V3 at the Restoration Hangar | National Air and Space Museum
setting aside number of parts vs a car, that thing is gonna need custom made parts just to restoe let alone becomr airworthy again. fascinating story Horten Ho 229 - Wikipedia
The only surviving Ho 229 airframe, the V3—and the only surviving Second World War-era German jet prototype still in existence—is on display in the main hall of the Steven F. Udvar-Hazy Center of the Smithsonian National Air and Space Museum (NASM) alongside other WWII-era German aircraft."Horten Ho 229 - Wikipedia"span. It is displayed partially restored, the wings of the aircraft displayed separately from the center section.
In April 1945, George Patton’s Third Army found four Horten prototypes, the Ho 229s and a Horten glider. Of three Ho 229s, the V3 was nearest to completion, and was shipped to the United States for evaluation.
Specifications (Horten H.IX V2)
Data from Nurflügel,[31] (Ho 229A)The Complete Book of Fighters[32]
General characteristics
Crew: 1
Length: 7.4 m (24 ft 3 in) chord at centre-line
Orthographically diagram
Ho 229A: 7.47 m (24.5 ft)
Wingspan: 16.8 m (55 ft 1 in)
Ho 229A: 16.76 m (55.0 ft)
Height: 1.1 m (3 ft 7 in) cockpit height
Ho 229A: 2.81 m (9 ft 3 in) overall height
Wing area: 52.8 m2 (568 sq ft)
Ho 229A: 50.2 m2 (540 sq ft)
Aspect ratio: 7.8
Empty weight: 4,844 kg (10,679 lb)
Ho 229A: 4,600 kg (10,100 lb)
Max takeoff weight: 6,876 kg (15,159 lb)
Ho 229A: 8,100 kg (17,900 lb)
Fuel capacity: 1,700 kg (3,700 lb)
Powerplant: 2 × Junkers Jumo 004B turbojet engine, 8.83 kN (1,990 lbf) thrust each
Performance
Maximum speed: 960 km/h (600 mph, 520 kn)
Ho 229A: 950 km/h (590 mph; 510 kn) / M0.77 at sea level; 977 km/h (607 mph; 528 kn) / M0.92 at 12,000 m (39,000 ft)
Cruise speed: 900 km/h (560 mph, 490 kn)
Never exceed speed: 1,000 km/h (620 mph, 540 kn)
Take-off speed: 150 km/h (93 mph; 81 kn)
Landing speed: 130 km/h (81 mph; 70 kn)
Range: 1,900 km (1,200 mi, 1,000 nmi) maximum
Rate of climb: 22 m/s (4,300 ft/min)
Wing loading: 130 kg/m2 (27 lb/sq ft)
Thrust/weight: 0.382
Armament
Guns: Ho 229A: 2x 30 mm (1.181 in) MK 108 cannon
Crew: 1
Aspect ratio: 7.8
Performance
Armament
Here’s the first Northrop flying wing, X-216H… circa 1928…
