Help IDing An Outside Mirror
65Fury440
West Central FL
I have this mirror, was going to buy another to match it, so I had dual matching mirrors.
The forward end has a screw doohickey on it, never paid any attention to it.
All the stock twin post mirrors I am seeing do not have that screw.
Any ideas? Aftermarket maybe?
I can't help with the identify the mirror, but keep in mind this is for a balanced look. The mirror is totally worthless to use from the driver's seat.
I added one to my '66, thought people were referring to the size not being useful but I can't adjust it to any position which would be useful.
I have a pair of these ......
There's the screw in end again. What car are those on?
Do you think you got them in the OEM position? I will heed your advice and make sure to get a good line of sight before mounting the mirror.
The twin post forward look mirrors all had the screw. Your mirror looks like a 62/65 style. The early ones had that screw. Could be a right side mirror.....?
[QUOTE="MoPar Maniac, Looks like an early 60s A/B unit to me.[/QUOTE]
That style mirror crosses over the entire forward look era, all models. I have two for my 61 Fury.
These are on my 64 imperial parts car.
Do you think you got them in the OEM position? I will heed your advice and make sure to get a good line of sight before mounting the mirror.[/QUOTE]
I placed them the same position as the driver's side. I would be curious if they actually mounted them in a different location from the factory. I believe if I would have moved the rear bolt hole more to the glass, it might be useful.
I would gain the help of another and see if you can find a sweet spot before anything is drilled and use a grease pencil to outline the base.
