Binky1945
i need a good used (right) passenger side fresh air door vent cable handle ***'y. It is about 1.5' in length and actuates a metal air cone thingee used to bring fresh air into the cabin from the passenger side thru the heat/cold levers using a vacuum system. It is a simple plastic finger pull device that mounts into the lower dash board panel underneath and to the right of the steering column. It has the word VENT imprinted on the front. The correct part # is 3431528
