Never worry about a rusted bolt
GOLDMYN
Chilton Wi
Kroil, This product is GREAT, you'll never have to worry about a frozen bolt, buy on inter-
net
Agree with the aeroKroil
Toss the WD-40 and never buy anymore.
You guys ever use PB Blaster?
PB Blaster is good and inexpensive, I still keep it around and it’s great for soaking things down the night before you disassemble. Kroil is THE best when you need it apart NOW!
My only use for WD40 is as starting fluid for 2 cycle engines.
PB Blaster has worked well for me every time. The key is dwell time. Usually overnight is all I needed.
Whenever you use WD-40 ever notice how the propellant runs out and your stuck with 1/3 full can that you can't use?
I had a can of some factory Rotunda Ford spray that was the best in loosening bolts.
I will try aerokroil. You can't buy it in stores?
I get it at a local fastener supply.
I've not seen it in stores, I buy on line
I get the impression this works better based on Matt’s endorsement above.
Every bit as good and maybe better. Already in a convenient applicator.
Hmmm. I might just give the acetone and trans fluid a try and put it in a squirt bottle.
I was under impression this worked faster.
