Finally got car on road. Speedometer works but odometers don't. Is this an electrical issue or mechanical?
I assumed they worked as speedometer registered.
Another related question. When I start down the road, the Speedo bounces all over the dial until I get up to about 30 then smooths out until I slow down again. I lubed cable from trans to cruise and from cruise to dash.
Cruise doesn't appear to be working yet hahaMechanical. Speedo speed cup drives the main odometer via a gear and the trip odometer is turned by a link to the main odometer.
Cruise transducer might be causing the bouncing speedometer needle as the speedometer cable to it is the cable from the transmission. The output from the transducer is what goes to the speedometer. The two are not directly connected, possibly? What happens if you set the cruise at 28mph?
Take care,
Try replacing the cable. I got one for mine, ready when needed.I did that. Speedo is perfect except for bouncing haha
