Mr onetwo
This guy has been selling a similar kit over on FABO for years....better quality than the Putco I believe. [FOR SALE] - Plug and play - Headlight Relay Kits
Octane also has a similar harness.This guy has been selling a similar kit over on FABO for years....better quality than the Putco I believe. [FOR SALE] - Plug and play - Headlight Relay Kits
Yep, Crackedback is on FABO and FBBO with his high quality hand built kits. It's good to buy from a fellow Mopar fan. FOR SALE - Plug and play - Headlight Relay KitsThis guy has been selling a similar kit over on FABO for years....better quality than the Putco I believe. [FOR SALE] - Plug and play - Headlight Relay Kits
He made me a custom harness for the Newport so I could run 100w high beams as it has 10 gauge power leads and grounds. It truly was plug and play.This guy has been selling a similar kit over on FABO for years....better quality than the Putco I believe. [FOR SALE] - Plug and play - Headlight Relay Kits
He did the same for me.He made me a custom harness for the Newport so I could run 100w high beams as it has 10 gauge power leads and grounds. It truly was plug and play.View attachment 546914
I was oblivious to this issue and thanks to John for figuring it out!So for those of you considering the harness upgrade and you have hideaway headlights, follow big John’s thread for the resolution
THAT is a HANDY tool! I resort to masking tape, carefully measured and leveled on brick walls as per instructions on my 50+ yr old vintage Everready-Westinghouse sealed beam lamp boxes. My headlight alignment suffices nicely for my uses, but I wouldn't mind using a proper tool such as yours, if I could score one. I suspect its too expensive for the rare use I would have for it though.One more thing...get the headlamps aligned!!
Makes a HUGE difference in lighting up the road.
Luckily, I have a vintage headlamp alignment kit.
The wall alignment works pretty well if you have the distance and a flat space.THAT is a HANDY tool! I resort to masking tape, carefully measured and leveled on brick walls as per instructions on my 50+ yr old vintage Everready-Westinghouse sealed beam lamp boxes. My headlight alignment suffices nicely for my uses, but I wouldn't mind using a proper tool such as yours, if I could score one. I suspect its too expensive for the rare use I would have for it though.
This stuff is pretty good at hiding bright wiring without looking cheap. Like the hard plastic corrugated stuff.
Amazon product
Alternatively I think vinyl paint would also work. I used it on some similar muli conductor car wiring and on home romex. Does not flake off. But will wear off if it moves around.
Amazon product
