My general question is: how can I use this wiring diagram to help diagnose why the pocket panel lights don't light up? I can't make head or tails of this diagram. The pocket panel lamps are at top left, but the lines don't connect up and the text is ambiguous. At the very top, for instance, there is a line where one side says "to instrument panel" and the other side says "to right rear door jamb switch." But how does that wire connect to the pocket panel? Are there better diagrams available, such as those shown in this thread: A logical diagnostic process... I'm asking this generally because I have other electrical issues and it would be good to be able to use these diagrams. I do see the color codes and legends.
My specific question relates to the pocket panel lamps. Neither light up. I was told they should light when the door is opened, like the map light does up front. I have the bulb out of the socket (driver side) and when I use a multimeter I don't get any voltage when I open the door, even thought the map light comes on. Since the door switch seems to work, what would be the next thing to check? The above diagram has text that says "to right rear door jamb switch." Does that mean the pocket panel lights only come on when the passenger door is open?
Finally, are there some good tricks for cleaning up sockets? I have a number of light bulb sockets that are pretty cruddy. The tail light sockets, for instance, are a little rusty and dirty. I sprayed some WD40 in one and wiped it down with a rag. That helped, but is there a best practice for cleaning up old sockets?
Thx!!
Thx!!
