Carmine
Inside a radio maybe?
No, but you jogged my memory...
AKA Mexican Laserbeam
You might not be able to find the correct white color, lol, but the fix might be as close as Home Depot.
Unbelievable. Handed to me on a silver platter. I am blessed!Found this on the Imperialclub site. They used weed wacker line for the repair!!
Chris Middlebrooks Repair Article: Imperial Power Antenna Mast Repair
Haha, Stan ;) Since you asked, I would serch for a repair part cable. If not availabe in the aftermarket, I would search for a similar one that is available. I've rebuild the antenna in my Mercedes lately and it had a similar cable inside. And it was much thicker then the weed wacker ones?!
Mercedes uses Hirschmann antennas, if you check ebay for these, there is a bunch of replacement masts with cable. (one piece)
Maybe you can adept such part. At least, that is what I would do.
Hirschmann Antenna Mast Part #900 000 13 17
Weed wacker line!!!
I'm gonna give that coated .125 cable a shot.Google "push-pull" cables. I think you'll find some steel cored plastic coated cables.
If I took that approach, I would try to get something that was purpose made to use as a push-pull cable. That way the coating would be up to the task and not break down.
I dunno.I'm gonna give that coated .125 cable a shot.
I think a steel coated cable is way overkill. This is an antenna, not a winch. You need a "weak link" should the antenna be obstructed for any reason, unless you prefer to ruin the mast or motor. Weed wacker line is more than adequate, probably the same as OEM except not 40 years old.
