power steering pulley
Early C Bodies - The Slab Side Years
  1. CARL J KUSTREBA
    CARL J KUSTREBA New Member
    13
    2
    Sep 10, 2020
    buffalo, ny
    good day all. curious as to how to remove the pulley on my power steering pump. seems to be the older trw as it has a slotted shaft end. it came on my 68 newport 383. cant find any info on it. thanks, carl
  2. mikedrini
    mikedrini Well-Known Member FCBO Gold Member
    558
    277
    Oct 9, 2017
    Center Barnstead, NH
    Easiest way is to buy or rent (Autozone) a power steering pulley puller-say that three times fast. Sounds obvious I know, but that's the truth. Looks kinda like this:
    There's also videos on BoobTube of how to do the procedure. Not too difficult.
    • Agree Agree x 1
  3. CARL J KUSTREBA
    13
    2
    Sep 10, 2020
    buffalo, ny
    thanks for the reply. what about the large slotted piece on the front? does it unscrew? or is the whole assembly pressed on? thanks ,carl
  4. Davea Lux
    8,547
    2062
    Mar 27, 2017
    Cornelius Or
    Download the FSM from www.mymopar.com, the manuals are in the Tools/Reference section from the home page. You will find the pulley removal instructions in Section 19. As noted it does take a puller.
  5. Big_John
    14,599
    9175
    May 21, 2013
    Marcellus, NY
  6. CARL J KUSTREBA
    13
    2
    Sep 10, 2020
    buffalo, ny
    thanks, did that, i downloaded the 66 & 70. my cars a 68. doesnt say much just to use a puller to remove the pulley. nothing about the slotted front of the shaft whether its threaded or not. have the puller just not sure if anything else is holding it. thanks ,carl
  7. 413
    413 Well-Known Member
    956
    294
    Jan 28, 2019
    NW USA
    It’s not threaded, just pull the thing off. The slot is an identifier for what size the pump is. Could have flat end, slot or hex.
  8. CARL J KUSTREBA
    13
    2
    Sep 10, 2020
    buffalo, ny
    ok....will give it a shot. thanks for the replies. thanks again, carl
    • Like Like x 1
