1. Old Mike
    Old Mike Member
    132
    183
    Nov 24, 2018
    Overbythere
    I don’t know if this topic has come up before. Has anyone had problems with carburetors gumming up on small 2 cycle engines (leaf blowers, trimmers, etc.)? A couple of guys around here were saying that the ethanol content in today’s gas when mixed with the 2 cycle oil was causing carburetor problems. I will say the one guy runs a lawn service, so his equipment sees heavy usage.
  2. cbarge
    cbarge Senior Member FCBO Gold Member
    1,695
    1956
    Nov 22, 2010
    Kingston Ontario Eh?
    No ethanol. Period.
    It will wreak havoc on small engines and classic cars too.
    Shell v power does not contain ehtanol.
    Other compNies you can check pump gas dot org
    • Agree Agree x 2
  3. Polara_500
    Polara_500 Senior Member FCBO Gold Member
    2,183
    875
    Apr 17, 2011
    Up North, you betcha!
    All my small engine gas gets sta-bil since I had to replace two carbs a few years back. No issues with anything since I started that. My old chain saw just started for the first time this year on the third pull.
  4. Old Mike
    Old Mike Member
    132
    183
    Nov 24, 2018
    Overbythere
    Thanks
  5. Davea Lux
    Davea Lux Senior Member FCBO Gold Member
    3,385
    847
    Mar 27, 2017
    Cornelius Or
    I have had good luck running the moonshine free "real gas" in all the small engines. It is more expensive than the blended fuels but more than pays for itself since the carbs do not gum up or corrode. On any two cycle engine it is a good idea to run it out of fuel before putting the tool away for the winter. This prevents the 2 cycle oil from seperating out of the fuel and causing hard starts. I usually take the spark plug out and give the cylinder a shot of oil to keep things free over winter.
    • Agree Agree x 3
  6. jct
    jct Senior Member
    2,632
    1405
    Jun 11, 2015
    indianapolis
    The mower i use at work accumulated a ball of gummy goo on the fuel float, dumped a loads of gas down the intake. Got it fixed with a new oil change...
  7. Davea Lux
    3,385
    847
    Mar 27, 2017
    Cornelius Or
    That white, brown or gray goo is the result of the ethanol picking up moisture and degrading. It is also corrosive and will eat up the lead seams on floats, the brass material of the floats and the pot metal bowl of the carb.
    • Agree Agree x 2
  8. Triple Pickle
    Triple Pickle Well-Known Member
    751
    891
    Jan 29, 2019
    USA
    Absolutely.
  9. thrashingcows
    thrashingcows Senior Member
    2,434
    881
    May 15, 2012
    British Columbia
    I run marine Sta-bil....even better then the regular sta-bil. I use it in anything that I have that runs gasoline. No major issues at all with my equipment.
    • Agree Agree x 2
  10. Walter Joy
    Walter Joy Member
    68
    63
    Jun 13, 2017
    Maryland
    Dad runs this stuff he calls “Rocket Fuel”. It’s $50 for 5 gallons, no ethanol, and no problems
    • Like Like x 1
  11. live4theking
    live4theking Old Man with a Hat
    7,162
    1514
    Nov 24, 2014
    Rockland; Venango County Pennsylvania
    Non ethanol fuel in my small engines and old car. Startron Enzyme treatment seems to have a good reputation also, available at NAPA and Tractor Supply.
    • Agree Agree x 1
  12. jct
    jct Senior Member
    2,632
    1405
    Jun 11, 2015
    indianapolis
    I get mine at Lowe's
  13. Old Mike
    Old Mike Member
    132
    183
    Nov 24, 2018
    Overbythere
    Thanks. I’ll be heading over to Napa fo sure
  14. mrfury68
    mrfury68 Well-Known Member
    755
    256
    Jul 15, 2015
    Bethel Park PA
    Ethanol is public enemy #1 when it comes to small engines and our beloved classics. I only use 93 octane gas, Sea Foam & Sta-Bil marine. No issues and my small engines are all older and I like to think, well maintained.
  15. shooter65
    shooter65 Senior Member FCBO Gold Member
    1,639
    1164
    Jun 18, 2013
    PA
    I also mix Sta-Bil in my gas cans for all my small engines. I also only use mid grade gas and I use the Sta-Bil mixed mid-grade to mix my 2-cycle gas. I've never had a problem since doing this.
  16. sixpkrt
    sixpkrt Well-Known Member FCBO Gold Member
    873
    1056
    Jan 18, 2013
    You can do a seach on the web that will allow you to find gas stations near you that sell non-ethanol fuel.
    I alway use the highest octane available when at the one near me.
  17. Rapidtrans777
    Rapidtrans777 Well-Known Member
    535
    310
    Dec 15, 2013
    Redneck Riviera
    Whether 2 or 4 stroke use ethanol free gas and you wont need to use or keep up with additives.
  18. Polara_500
    2,183
    875
    Apr 17, 2011
    Yeah, but if you go through as much as I do, (around 8-9 gal/wk summer), and the nearest non-ethanol gas is 30 miles away it just ain't worth the trouble.
  19. BLUPORT
    BLUPORT Carpe Diem Cras FCBO Gold Member
    897
    721
    Dec 10, 2018
    Eastern NC
    I have been pouring Naphtha in my tanks, and it seems to help a lot. YMMY, purely anecdotal.
  20. Jon O.
    Jon O. Well-Known Member
    569
    302
    Sep 19, 2017
    Indianapolis indiana
    A half glass of water slowly poured down the carb while it is running will have the same effect as sea foam.
