Do you think that defective lifter you had a problem with finally let go and maybe the valve isn't closing?
Nah. I replaced that lifter and the rest with all brand new ones about year and a half ago. The cam was still fairly new at that time and unscathed so I got lucky that time.Do you think that defective lifter you had a problem with finally let go and maybe the valve isn't closing?
That is fuggly.View attachment 38412View attachment 38413
Yep. A chip in the valve would cause a rough idle, and poor running condition.
I've been an auto machinist all my life and have seen hundreds of failed liners. The best way to do it right is to eliminate all possible problems. I was absolutely floored when Mike Sullivan told me they were using guide liners in their race engines back in the ninety's. He learned the hard way. Guide liners work just like cast rings work. Why not spend a couple bucks more and get something bullet proof like real guides and moly rings. Actually knurling guides is an OK idea so long as the guide isn't worn out. Most valve guide mfgs. offer knurled guides for replacement and Oldsmobile knurled the guides on all their engines from the sixties through the eighties. Typically Olds guides were always in good shape. This is what happens when you have a machine shop owner join your forum.ops: Just my 2 cents.
