Should i spray anything?
Electrical & Ignition
  1. carguy300
    carguy300 Member
    80
    26
    Jul 29, 2018
    East Texas
    I got my new engine compartment harness for my 300. Is there any kind of grease or protectant that i should apply to the bulkhead connection when i install the new plugend assembly?
  2. Davea Lux
    5,222
    1362
    Mar 27, 2017
    Cornelius Or
    The bulk head connector usually has a rubber gasket to keep water out, the gasket should be replaced when replacing the connector. Some models also had a plastic shield above the connector to deflect road splash, be sure that is in place. I am not a big fan of putting a lot of gunk on connectors because at some point the connector may need to come apart and all that stuff has to be cleaned off. If you are going to use anything, use some WD 40. WD does a pretty good job of displacing moisture.
    • Agree Agree x 2
    • Disagree Disagree x 1
  3. carguy300
    carguy300 Member
    80
    26
    Jul 29, 2018
    East Texas
    Thanks Dave. I was thinking WD40, just wanted another opinion. I have not unplugged the old one yet to see about the rubber gasket but i will ck it for sure.
  4. Newport 66
    Newport 66 Senior Member FCBO Gold Member
    4,291
    2823
    Aug 6, 2017
    Lancaster, WI
    I use dielectric grease on connections and lamp sockets, plug wires etc.
    • Agree Agree x 14
  5. Zymurgy
    Zymurgy Old Man with a Hat FCBO Gold Member
    6,024
    4523
    Sep 14, 2012
    London, Ohio
    I would first clean the connections with denatured alcohol and pipe cleaners. I personally would not use WD-40, but that's just my opinion.
    After cleaning I agree with dielectric grease, a little goes a long way.
    • Agree Agree x 6
  6. cbarge
    cbarge World Famous Barge in a Budget FCBO Gold Member
    2,284
    2980
    Nov 22, 2010
    Kingston Ontario Eh?
    Dielectric grease on ALL connections..
    • Agree Agree x 3
    • Like Like x 1
  7. rkrochen
    rkrochen Well-Known Member
    563
    369
    Jun 29, 2015
    Teulon, Manitoba
    I agree use only dielectric grease. Years ago I took a gunsmith course and we talked about using WD40. We were discouraged from using it entirely and since then I have only used it infrequently when nothing else was available. It temporarily helps but is not for long term usage.
    Dielectric grease is designed for this type of application and you don’t require much.
    • Agree Agree x 1
  8. Big_John
    12,005
    7028
    May 21, 2013
    Marcellus, NY
    Not a fan of dielectric grease myself. IMHO, most people use it incorrectly. The word "dielectric" roughly means "insulator". Look it up...
    What I do is to clean the contacts with De-Oxit. It cleans and helps protect the connectors. This bottle will last you years.
    https://smile.amazon.com/CAIG-Labor...=sr_1_6?keywords=deoxit&qid=1578877024&sr=8-6
    If you want to use dielectric grease, the correct way is to coat the outside of the insulator where it plugs into the connector to seal the connections.
    • Agree Agree x 3
    • Like Like x 2
    • Thanks! Thanks! x 2
  9. Ross Wooldridge
    Ross Wooldridge Senior Member FCBO Gold Member
    2,471
    744
    Apr 25, 2016
    Scotland, Ontario, Canada
    Dielectric grease.
  10. live4theking
    live4theking Old Man with a Hat
    8,289
    1853
    Nov 24, 2014
    Rockland; Venango County Pennsylvania
    I'm with Big John on this. De-Oxit is the way to go. It will clean any corrosion that is present and prevent future corrosion. This is by far the way to go. We use it on all of the high voltage grounds of dissimilar metals on our products, high voltage I mean lightning strikes.
    • Thanks! Thanks! x 1
  11. Joseph James
    Joseph James Well-Known Member
    977
    519
    Jul 21, 2018
    Asheville, NC
    DeOxit is the best sh*t there is for cleaning electronics and contacts. I’ve seen it resurrect pots that I thought were done for. Not sure how it would work for keeping moisture out in harsh automotive applications. I like dielectric grease myself.
  12. The Goose
    The Goose Senior Member
    1,528
    2118
    Nov 21, 2016
    Santa Clarita ca
    Bingo !!!
    This is one our biggest problems w big gen sets at crushers sites. The powdery nonconductive material gets into those connections & the grease only exacerbates the situation. We’ve brought “I’m done write it off” gen sets back to life w just a good cleaning. I know cars aren’t usually in that kind of stuff but if you’re living in a fairly dry area I’d skip it. Just my 2 cents (and tens of thousands of customer dollars into our shop’s coffers Lol!!!)...
  13. carguy300
    carguy300 Member
    80
    26
    Jul 29, 2018
    East Texas
    This is why i love this place! All the imput. Can i get this De-Oxit at any of the parts houses? I have never heard of it.
    • Agree Agree x 1
  14. Joseph James
    977
    519
    Jul 21, 2018
    Asheville, NC
    Big John posted an Amazon link. I buy mine from Amazon. If Radio Shack still existed they would probably sell it, or an Archer branded version :)
  15. carguy300
    carguy300 Member
    80
    26
    Jul 29, 2018
    East Texas
    I ckd out the site, was just hoping i could pick some up local. My car has been down a month waiting on parts and i'm missing out on warm texas driving time!
  16. Joseph James
    977
    519
    Jul 21, 2018
    Asheville, NC
    I feel you. My Fury is down a week now and wife wants her basement garage back.
    Amazon ships pretty quick. 2-3 days?
  17. carguy300
    carguy300 Member
    80
    26
    Jul 29, 2018
    East Texas
    Luckily we have 2 garages so mines safe and out of the texas weather.
    • Like Like x 1
  18. CBODY67
    CBODY67 Senior Member
    4,061
    940
    Mar 27, 2011
    Rather than using WD-40 to spray the exterior of the connectors, what about some of the new silica dioxide paint protectants (see YouTube videos)? I concur on making sure any OEM gaskets are replaced with new ones. Might do a test fit to make sure all of the connections will be firm and tight when in the car.
    My machine shop operative used to use WD-40 was a protectant on freshly honed blocks and such. When I tried it in my shop, light surface rust happened. So any protection probably evaporates over time. By observation, dielectric silicone will become waxy-looking and dry out over time, as it might also shrink a bit, too.
    I suspect that if you put everything back "dry" to OEM specs, with new gaskets and such, you'll have a good 20 years or so before any problems might surface? Sometimes in trying to make things better, other issues are created also. Your judgment call.
  19. live4theking
    8,289
    1853
    Nov 24, 2014
    If you have a local electrical store that sells to contractors that is where I would go.
    • Agree Agree x 1
  20. mrfury68
    mrfury68 Well-Known Member
    922
    351
    Jul 15, 2015
    Bethel Park PA
    I never realized De-Oxit also helped protect the contact surfaces. Learn something new everyday.
    • Agree Agree x 1
