Anything I can do to offset the damaging effects of RFG?
Not true, sitting and evaporating causes the jelly like crap that forms on the floor of the float bowls. Constant driving or at least consistent use would extend the formation time of that crap. IMODon't drive.
Nope outboard oil is ashless and burns clean to not contaminate water/fishI drive her. I've never heard of the 2 stroke oil trick. No plug fouling issues?
I hear reformulated gas is murder on carbs. Anything I can do to offset the damaging effects of RFG? The nearest station with real gas is 40 miles away
Guess I will have to run it on love not fuel.Then, don't buy any gas!
Outboard 2 stroke oil with tc3 2 oz per 5 gallon of gas. Coats the internal parts with some oil and burns clean through combustion chamber.
Stabil keeps the gooey by-products of the ethanol breakdown from coating the fuel system. Ethanol blends are always going to be crap. Also keep in mind if you decide to use Stabil, that it cannot be used with most octane boosters as they are not compatible and will produce even nastier problems when mixed together in your gas tank.
Yes that stuff.This stuff...
This is scary in the fact that if you use the car to take a trip and use gas from different refineries, tank farms, retailers. What kind of deadly mixture is brewingkeep in mind if you decide to use Stabil, that it cannot be used with most octane boosters as they are not compatible and will produce even nastier problems when mixed together in your gas tank
You're WRONG!!!I'm just gonna say this and i'll surely be told that I'm wrong..
I just finished driving a dead-nuts original '79 Magnun (318-2) in a two mile parade. It took roughly an hour, so 1/2 mph. Car didn't do a single thing wrong, then I ate lunch with the family of the Navy vet who rode with me. (aka heat soak) Then I drove it home without incident. Only in the middle of the parade did I remember I was running on the last 1/4 tank of the 87 oct. cheap gas (probably from our local Kroger) that was in it when I garaged it 8 months ago.
Basically repeat the same story for my '70 Fury (sans parade).
Same thing with my Monaco, except I burn a lot more Kroger or Ghetto-brand gas. No electric fans, pumps, gadgets, additives, etc.
I don't do anything with my lawn equipment except run it dry on the last cut.
I don't think I've purchased more than a couple tanks of name-brand fuel in my life.
YMMV
There is a product called Lucas Ethanol treatment . You can get that at Walmart or your local auto parts store . I keep a bottle of it the trunk of my '61 in case I need it.I hear reformulated gas is murder on carbs. Anything I can do to offset the damaging effects of RFG? The nearest station with real gas is 40 miles away
