cruisinwithsusan
The top on my 300 is sluggish at best. It needs a lot of help to get it up, so to speak. I'm looking for advice on what all I should replace and best source for the best parts. Thank you in advance.
to check the fluid level and bleed the system you will have to take the back seat outThank you. I'll investigate the fluid level. All new to me. Thanks again.
Convertibles haven't used brake fluid since the 50's. If you think about it, the last thing you'd want in plastic lines that could leak is brake fluid.The "fluid" which is spec'd for your car could well be brake fluid
The biggest thing that slows the top down is the electrical current drop from the switch and wiring.Yes, now that you say it, that's what it sounds like. Can you offer any more insights on updating the lines and cylinders? Where should I look for those parts? I've yet to lay eyes on the cylinders and lines but have always worried about a line bursting and the resulting mess.
same on my '69. i used a plow pump solenoid wired straight to the battery. top goes up like a catapult. had a leaking cylinder and replaced it with a new o.e. ford cylinder for a '97 mustang.I use a relay on my '70 300 vert and the top is much faster.
Just having the car running while putting the top up/down helps too.Now that you mention it, the old salt who helped finally replace the original top last year said, "funny thing, when I hooked the battery charger up to that car the top went just fine". Or something along those lines. Maybe some lube, fluid check and an electrical boost will do the trick. I'll check out the YouTube resources too. Great stuff, thanks.
Well, apparently GM did not get that memo. Reason I say that is that my '68 LeSabre convertible specs "brake fluid" for it. Even recommends periodically wiping the extended rams rods with a rag soaked in brake fluid, to keep them clean. The service manual DID mention how bad brake fluid treated any paint or soft trim, so that advisory is there.Convertibles haven't used brake fluid since the 50's. If you think about it, the last thing you'd want in plastic lines that could leak is brake fluid.
It will be ATF and there should be a label on the pump.
From the 1970 Chrysler FSM. Section 23-68Well, apparently GM did not get that memo. Reason I say that is that my '68 LeSabre convertible specs "brake fluid" for it. Even recommends periodically wiping the extended rams rods with a rag soaked in brake fluid, to keep them clean. The service manual DID mention how bad brake fluid treated any paint or soft trim, so that advisory is there.
Google led me to a Buick Forums post where brake fluid was still used in 1966, so I suspect 1968 would be similar, if not the same.
But in the AACA Forums, was an image from a 1971 Cutlass convertible, with the orig pump, which had a label specifying "ATF", which would have been a GM Dexron item at that time. Did not mention Dexron specifically, though. Wonder if Type F would make it quicker?
What I figured out was that "convertible top fluid" had to be a fluid which was readily available in the boondocks, should it be needed, in any year. Even until the later 1960s, almost every service station had a gallon of brake fluid, for top-offs and brake system repairs. By that time, atf was also common, but usually "by the quart", although Exxon had some pint cans.
The issue with brake fluid is its desire to absorb moisture. Whether in a convertible top system or a hydraulic brake system.
After the 1960s ended, many service stations had a variety of fluids for sale, with more availability today with "free shipping" and all. I concur that atf is a better deal, but it can still damage some surfaces in convertibles. In any event, taking a samle of the fluid in the system, from the reservoir, would be advisable! Then proceed from there.
Not trying to disagree at all... Just showing my source.@Big_John, NOT disagreeing or challenging, just that apparently GM was behind Chrysler in adopting atf in their top systems. Obviously, if any updates to the systems are made, they should be compatible with atf or similar.
And, after researching the FSMs at www.mymopar.com, I just now discovered that Chrysler changed from brake fluid (as their spec fluid in convertible top systems) to atf for the 1964 model year. BTAIMNot trying to disagree at all... Just showing my source.
I'm actually surprised that GM still used brake fluid that late. Most of the convertible stuff I've seen is very generic and I would have thought that all the manufacturers had gone to ATF by then.
Whew, thanks. I was wondering.to check the fluid level and bleed the system you will have to take the back seat out
