66FuryIIINB
Greetings everyone!
I have a 66 Fury 3. Temp gauge pegs out hot when headlights or heater fan is on.
Runs about 3/4 when no electrical draw on the system. Engine shows no signs of overheating. Everything original on this car. Fuel gauge is factory and works even internal dash voltage regulator stock. Gauges seem to function as they should. Cleaned bulkhead connections. Don't know if it matters but New ballast resistor and main voltage regulator. Ignition coil condenser and points all replaced. It has been doing this since before all replacements mentioned above. Also checked block to frame ground connection. I'm at wits end can anybody help?
Thanks
Thanks
