tilt wheel parts
hemidon
Ft Pierce Fla
Fellow Mopar lovers---Im working on a 1965 Plymouth Sport Fury convertible with tilt steering column and Im having a time trying to find the turn signal switch cable that runs inside the column down to the actual switch at the bottom of the steering column. This unit is in bad shape and hardley moves in the shieth--can anyone steer me to a source for this cable? It is 24-1/2 inches overall and the shieth is 22-1/2 inches long--also is there a source for the horn contact ring for the tilt wheel ? -Thank you all
I suspect that might be a Saginaw-sourced (i.e., GM) column, so possibly a similar Impala/Caprice cable might work, IF the lengths are compatible.
Just a thought,
I know it fits my '66 Monaco with the Sagnaw steering column with the chrome telescope lock ring in the center of the wheel.
Past that, I'm not sure
With or without cornering lights?
