That style of differential has been around since about 1963.
Maintenance on a clutched ltd slip differential is a non-issue, from my experience. Just use quality lube and the friction modifier additive to it.
On a rwd ltd slip axle, torque steer is not an issue on flat and level ground, paved or otherwise. Whereas torque steer on fwd cars can always be an issue. Allegedly, the more-equal the fwd axles are, the less torque steer results. More power, more possible torque steer, though.
Now, there are two types of "plated" ltd slip rear differentials. One is the prior style of "locked until it unlocks" (which HAS to have the friction modifier additive in the lube) and the "governor-weighted" style of "unlocked until it locks". The prior style can either have 4 individual tension springs or an S-shaped single tension spring. FEW of these will have complete lock-up, when "locked", though. Allegedly only about 75% lock-up. Whereas the "locker"-style will have complete lockup where one wheel will drive the vehicle forward with only ONE wheel touching "ground". Many GM dealer-training vids on this!
Just some thoughts and my experiences,
