Mr Grumpy
Well I'm getting on with the Fury, it's now running pretty well thanks to a new pertronix distributor (old one had over 30 thou lateral play at the cam ) new Accel coil (old one was a ballast coil with no resistor), plugs (broken tip insulators and bent contacts), Accel 8mm plug leads (originals held together with insulting tape).
So I'm thinking that if the dizzy is that worn, the original 2 barrel carb probably is too, which leads me to my question, what to replace it with?
Your thoughts would be welcome. TIA.
