Where to buy a reman 68 440 engine
  1. Biggredd2069
    Biggredd2069 Active Member
    248
    32
    Oct 26, 2018
    Parker, CO
    Casually looking for a remanufactured 68 440 for my newport. Suggestions? Don't wanna have to rebuild one.
    • Thanks! Thanks! x 1
  2. Davea Lux
    5,535
    1447
    Mar 27, 2017
    Cornelius Or
    If you want a genuine '68 motor, you will probably need to rebuild the one you have. Reman engines are promised "to fit" but they will rarely be a date correct engine. If yours is not rebuildable, or you are upgrading to a bigger engine, you will then need to find a '68 core and rebuild that.
    The other option would be to check out auto trader or the nickel ads, every once in a while a fresh motor will show up from a wrecked car.
    • Agree Agree x 1
  3. Biggredd2069
    248
    32
    Oct 26, 2018
    Parker, CO
    Mine might have a crack. Waiting for confirmation
  4. Newport 66
    Newport 66 Senior Member FCBO Gold Member
    4,739
    3087
    Aug 6, 2017
    Lancaster, WI
    If you have to have a date coded engine, be prepared to hit the MoPar sites, Craigslist, Marketplace or Wrecking yards. Be patient and best of luck!
    • Agree Agree x 1
  5. commando1
    commando1 Old Man Wearing a Hat on the Porch FCBO Gold Member
    33,145
    18220
    Mar 10, 2011
    FUHOA Reservation, Sebring, Florida
    Or get dirty pulling one from a Winnebago.
    • Like Like x 2
  6. polara66hardtop
    polara66hardtop Senior Member
    1,276
    405
    Jan 6, 2014
    Omaha nebraska
    I understand you don't want to build one, but hearing a seller say it is rebuilt does not necessarily mean it it was done right. I am not very trusting, unless I know who did it.Like Reagan said, Trust, but verify.
    just friendly advice!
    • Agree Agree x 3
  7. Joseph James
    Joseph James Senior Member
    1,100
    603
    Jul 21, 2018
    Asheville, NC
    I bought a 383 from S&J Engines. 7 yr/100k mile warranty if a mechanic installs it. I have been very happy with my reman engine. They have some YouTube vids of their facilities.
    I guess I got lucky. My reman has a 67 date code like the old one. It is not something that was important to me. My car isn’t ever going to be a concourse car.
    There is also CME. I think a member here had an engine built by them. Their place is near Aiken. I have been right by it. They will rebuild your engine and are pretty reasonable. I actually spoke with them on the phone before I decided on S&J.
    Rebuilt Engines and Rebuilt Motors from CME
  8. 1978 NYB
    1978 NYB Warfighter FCBO Gold Member
    45,261
    15682
    Apr 16, 2011
    Classified
    Yep I bought an engine from CME.
    • Like Like x 1
  9. CBODY67
    CBODY67 Senior Member
    4,132
    966
    Mar 27, 2011
    There should be some Mopar clubs in your part of the world, or thereabouts. They might have some leads on rebuildable engines and where to get them rebuilt.
    Somewhere along the line, some of the mounting bracket sets and where they attached to the block changed. Not sure of the model year break, but probably relates to the earlier '70s or so? Just to make sure you have all you need, better to get a rebuildable COMPLETE core engine from a salvaged car. With all of the brackets attached to the front of the engine. Might need some alterations to the motor mounts if it's a later model block that has the spool mounts?
    The reason I mention this is that a customer bought a '56 Dodge from a national-ranked auction. Really neat car! 440, Dakota front k-frame, etc. While our tech was getting it checked-out and such, the engine developed a lower-end knock. The owner just ordered up a 440 short block. The "new" one had different mounting bosses (for the mounting brackets) than the existing block had. The tech had to search for different brackets and such to get the replacement short block to work. Didn't check the date codes on the blocks, so not sure of what was what in that respect. BTAIM
    Where's the crack suspected of being? Just curious.
  10. Biggredd2069
    248
    32
    Oct 26, 2018
    Parker, CO
    The crack is suspected, waiting for confirmation. Doing homework right now. It's in a shop. I can't wait too long to pull the trigger on something if it is cracked.
  11. polara66hardtop
    1,276
    405
    Jan 6, 2014
    Omaha nebraska
    if you definitely need a 440 to rebuild, I have one in Omaha.
  12. Biggredd2069
    248
    32
    Oct 26, 2018
    Parker, CO
    The original owner told me the car had been rebuilt as some point. Is a 383h factory 4 barrel. I had some carb issues and ended up going fuel injection. It exaggerated an existing issue on the timing chain and it broke. So in the process of getting a new timing chain they said it was milk shaked in there and said there was either a head gasket leak or possibly a crack. They said it didn't look ever rebuilt either. They are investigating now, no idea where a crack may be. But since this is the 4 barrel version I heard the 440 upgrade is an exact fit so might upgrade if I have to go full steam in this project. I may get lucky and just rebuild the damn thing too. I'll know soon.
  13. 1978 NYB
    45,261
    15682
    Apr 16, 2011
    Classified
    Another alternative......
  14. halifaxhops
    halifaxhops Senior Member
    1,029
    232
    Mar 10, 2017
    hALIFAX, pa
    You can stitch weld(not welding) almost any crack. Did a thread on it. I will keep my eyes open when I do searches for you.
    • Like Like x 1
  15. halifaxhops
    1,029
    232
    Mar 10, 2017
    hALIFAX, pa
  16. 69 300 vert
    69 300 vert Active Member
    320
    507
    Jul 17, 2016
    Taxus
    If your car has A/C and you're keeping it, the 440 will need the 440 specific rear A/C mount bracket. As near as I recall that's the only caveat in swapping in the 440. 2¢
  17. MEV
    MEV Active Member
    203
    189
    Mar 28, 2015
    WA
    Sounds like they are correctly implying a blown head gasket or a cracked cylinder HEAD. I would seek clarification. Cracked heads are more common than cracked blocks.
    • Agree Agree x 1
  18. polara66hardtop
    1,276
    405
    Jan 6, 2014
    Omaha nebraska
    i did have a cracked block once on a 1967 440. It was across the passenger side near the casting numbers. It only showed up warmed up. think it got froze once.
  19. Ripinator
    Ripinator Senior Member
    4,322
    2318
    Jul 31, 2013
    Germantown, MD
    You'll probably need the cast front cover for the water pump too. On my 440, I had to use the front cover off of the 383 I swapped out. Mine has A/C; the front cover for that is different.
