1966 Newport - Ignition Wiring
Electrical & Ignition
  1. Lemieuxport
    Lemieuxport New Member
    6
    4
    Sep 22, 2016
    Cincinnati, Ohio
    I am working on the installation of new wiring in my 66 Newport and was wondering if there should be a 10ga wire from the positive battery terminal running directly to the starter relay or if the only thing coming of the positive battery terminal is going directly to the starter.
  2. Ripinator
    Ripinator Senior Member
    4,631
    2550
    Jul 31, 2013
    Germantown, MD
    If yer re-wiring your '66, you really need one of these:
    1966 Chrysler Color Wiring Diagram
    Get the BIG one.
  3. Davea Lux
    7,172
    1920
    Mar 27, 2017
    Cornelius Or
    That wiring leg (from the positive bat terminal to the starter relay) also contains the fusible link, so be sure to install it properly so you do not get a short someplace and toast your new harness. There should be another heavy gauge wire from the firewall plug to the positive battery terminal on the starter relay to feed the fuse block, ignition switch and the rest of the passenger compartment wiring. Those two leads go to the big terminal on the relay. There will be a third light gauge lead to the ignition switch to energize the relay, opposite this lead there is another light gauge lead from the neutral safety switch to ground the circuit that energizes the relay. There is a 5th heavy gauge wire to the starter solenoid that is is activated by the energized relay.
  4. Gerald Morris
    Gerald Morris Well-Known Member
    975
    227
    Mar 9, 2016
    Tucson
    I use an #8 gauge wire now, with a #12 ga fusible link on my '66. I run #8 to the battery from the alternator, also protected by #12 fusible link wire. Make the link(s) no longer than 6 inches if you do your own. Have you eliminated the ammeter and straightened up the wiring under your dash yet?
