- Joined
- Nov 14, 2010
- Messages
- 28,133
- Reaction score
- 27,267
Did you find a spot for your cocktail glasses?
I can assume then, that the 1970 engines did not?All the 69 engines had a steel crank.
Yep, you can all follow along, back at the build thread when the process starts.Whatever you do please keep us posted. It would be interesting to follow.
I will have to pull this one apart, I may need some help figuring out if this is a good core or if it had been rebuilt in the past. The heads have two different casting dates, don't know if that means if it was updated at one point. The transmission was newer, from a '74, I think I have the better unit with that at least. Thanks all for the replies!
James
Ok, so don't I want lower compression for a driver that will need to run good on pump gas?
Originally I was going to rebuild it, and get the 1970 valve covers and air cleaner to make it "look" like a 1970.
Do NOT forget about hardened valve seats in the heads.Ok, so don't I want lower compression for a driver that will need to run good on pump gas?
If there is a difference in the valve covers and if you are planning to replace the stock ones, I would be interested in them if they are free of dings and dents!
