FinallyGot1
So I got my motor on a stand and I'm all set to slide my cam in. New cam bearings are in & cam spins smoothly. I have a bottle of Clevite Bearing Guard I was planning on using liberally on all my rod & main bearings and thought it'd be good stuff for cam bearings as well. Good idea or not?
Also, when I ordered my cam from Crower, they included a little packet of Joe Gibbs Driven Assembly Grease. I didn't know they were going to do that so I also ordered a small packet of ZPaste assembly lube. I was planning on using the ZPaste on the cam & lifter bases but I don't think this one little packet (0.625 oz) is going to be enough. I say this because I remember an article in a hot rod magazine (probably Car Craft or Popular Hot Rodding if it matters) where they were installing a new cam and they showed the cam lobes absolutely slathered with moly EP grease. Is this ZPaste stuff a totally different animal than the grease they used "back in the day"? Now I only need a dab where they used to use a healthy glob?
I also have a big tube (10 oz) of Sta-Lube engine assembly lube that has moly-graphite in it. This stuff says it can be used on everything (probably not piston rings though.....motor oil for them). So would it be better to just use one kind of assembly lube as much as possible or use different lubes for different parts? I know it only matters for the first few seconds of running but it's a real important few seconds....particularly for a flat tappet cam.
It's very likely this engine will sit for a few months before it goes in the car. Does that make a difference in assembly lube choice? Methinks thicker & greasier would be better but I know squat about building a motor.
TIA everyone!
Hope you all have a nice turkey coma tomorrow.
TIA everyone!
