66PolaraGrzzy
Hi guys, when a restoration is taking place, what is the best way to deal with the existing bolts, clean and refinish or try and get new?
I am in the process of putting my 65 SP back together and referred to Auveeco catalog and they have a ton of stuff but frankly not much help. First, you have to know exactly what you want, need to know your part numbers and then convert to theirs and I found it confusing at best. Mouldings are difficult to find but the universals can be found locally or the internet. As suggested, I cleaned as much as possible with grinder for use and take along on the hunt. Automotive paint stores are a big help. Good luck.You can go either way.
To keep costs down, bag and tag all hardware and clean them up on a wire brush on a bench grinder.
If you want new you can go through Auveeco catalogue.
Very handy resource especially for the speed clips that do break and you will break off bolts too!
Homepage
