- Joined
- Nov 14, 2010
- Messages
- 27,947
- Reaction score
- 26,890
This one looks very nice.
1971 Chrysler New Yorker
***Vehicle is currently located in Windsor, Ontario, Canada. Viewing arrangements can be made on weekends. Please contact me with questions.***
Numbers-matching, 64000 original miles, 3 owner, Ontario car that was owned by a Snowbird who spent winters in Miami (receipts to prove it). As it was undercoated, and garage-kept, it does not appear to have ever been driven in the salt.
440 4-bbl, 727 Trans, 8 3/4 rear axle. Originally burgundy, repainted once in a gorgeous burnished red. Interior is black with woodgrain trim, with the original blue paisley/black vinyl seats (I don't have pictures - come see it!). Power fr disc/rr drum brakes, Power steering, Non-A/C car. AM radio. The only option it has is a rear defroster.
Averages 16 mpg on the highway. Drove to Marquette, Michigan and back last July without a single issue. Drive anywhere.
Recent maintenance:
New TTI 2.5" Dual exhaust with H pipe crossover and Dynomax mufflers with Gibson chrome turndown tips (nice rumble, very reasonable volume)
Reconditioned 2.25" Exhaust manifolds from a '69 roadrunner
Brakes were recently serviced (2000 miles ago), stops without an issue.
Re-cored radiator (originally 2-core, now a 3-core)
New upper and lower rad hoses
New water pump
New belts
New fuel pump
New alternator (72+ squareback type - improved reliability, have original)
New NGK plugs and wire set
New pertronix hall effect kit (fits under distributor cap, improves spark and reliability)
K&N air filter
New PCV valve
New washer bottle (not-original, seems these are hard to find)
New starter
New motor mounts
New trans mount
New front shocks (Monroe)
New rear shocks (Gabriel)
New idler arm
New P235/75r15 Hankook Whitewall Radials (2000miles)
New interior carpet
New turn signal switch (internal to steering column)
Fresh trans fluid
Fresh oil
New battery
New battery cables
Rebuilt tail light housing, new tail lamp sockets and bulbs, was able to re-pin the original connectors so the main harness is untouched
New front headlight bulbs
Have all receipts
Everything works right down to the rear defroster, though it's never driven when cold enough to need it. Needs nothing really.
Reason for sale: Busy with new job, it's difficult to make time to give it the attention it deserves. Comes with a dual snorkel air cleaner, a set of period-correct 15x7 police rims, car cover, and a 1971 Chrysler factory service manual set.
$7000 USD OBO. No trades, please.
Recent maintenance:
New water pump
New belts
New fuel pump
K&N air filter
New PCV valve
New starter
New motor mounts
New trans mount
New idler arm
New interior carpet
Fresh trans fluid
Fresh oil
New battery
New battery cables
Have all receipts
