I tried to change the title when I got the year wrong, but couldn't find out how.I would just keep the same thread As before and change the title so we could follow your whole progress in one thread.
That trim is a press/crimp fit. No fasteners. I used a small oak block and hammer to work it off. Just work it down a little at a time, do not pull on it.
So what are your plans with this car? It looks like a good base to work with.
That was easy!
But that leading edge on the drivers door I am guessing has screws poking through from the frame...
I have the vent windows. Does that have to come out first? I can see the screw but looks a long way away from the trim...Leading edge trim...open the door, you'll see the screw.
That might work. I was a little nervous about taking the vent window and door apart. I have a big enough headache with the rear door trim!Perhaps I am unclear about what trim you refer to...
The leading edge of the upper sill trim is held in my the screw I referred to.
The sedan pillar trim around the door glass is pressed on like the rest you removed. I believe you will need to loosen the vent assembly and lean it back to pull the trim.
Yep. And the monster parts book (about 8" thick). Unless I have the wrong factory service manual (called a chassis and something manual), it has very limited info on either the wagon or a lot of the assembly of the car. I haven't yet looked up the exploded view in the parts book. That has been OK for assembly of parts, but not great. I have not found a factory assembly manual yet for this car.ill say it -
have you bought a service manual yet?
try not to bust your bunker -
- saylor
I find the FSM useless in helping how to disassemble body parts.ill say it -
- saylor
You're right! I forgot about that. I looked at the tailgate for other stuff and saw no handles (maybe they are permanent) but I did see something on getting the wind wing off. That will be next and I may find holes for the grab handles if I tear enough apart.I find the FSM useless in helping how to disassemble body parts.
Good for electrical and mechanical components but stuff like those grab handles not so much.
The parts book is good for that because they show it in explosion form. Except in your case, of course. lmao. They don't even show the damn handles...
