moonrunner1972
- Joined
- Mar 14, 2011
- Messages
- 231
- Reaction score
- 22
Greetings fellow C-body enthusiasts! Once again I bring you my mechanical problem for your advice. The previous owner of my 1973 Polara had the wheel studs spot welded into the axle shaft flange. The threads on the studs are beginning to become increasingly difficult to thread the lugnuts onto. Should I try my luck at the hinged thread restorers or do the typical thread repairers do the trick? Or, should I simply find a new set of axle shafts?
