bluefury361
I can't seem to determine this in the parts book. Will a 1967 Chrysler 300 dash pad interchange to a 1967 Polara?
Thanks
Will.
Thanks
Will.
This is in the interior section often missing from original hard copies. I have hard copies of the 67-69 books but use the PDF most of the time.I figured that might be the case. Thanks for checking. I think there may be some pages missing in my parts book.
Will....![]()
Where do you get the PDF?This is in the interior section often missing from original hard copies. I have hard copies of the 67-69 books but use the PDF most of the time.
Alan
Parts Manuals – MyMoparWhere do you get the PDF?
Shouldn't matter as long as it's from a '67 Polara.Are there any dashes that will interchange with the 1967 Polara? Mine is a 500. Not sure if that makes a difference.
Thank you. I will look at it this weekend.Go here and download the 67 and 68 parts manual. If the p/n’s match in both years they will interchange.
There is a possibility that ‘68 might work but the Instrument panel changed and in ‘68 there were standards implemented for better padding on the dashboard. ‘68 also added lower dash padding, so not sure if the uppers will work.
Well, that was more confusing than Calculus.Go here and download the 67 and 68 parts manual. If the p/n’s match in both years they will interchange.
