Exhaust getting into interior
Mopar Exhaust Systems
  1. Jack Ryan
    Jack Ryan New Member
    9
    0
    Apr 20, 2019
    Belvidere, IL
    I need help. 1965 300 4dr HT exhaust getting into the interior. The only thing that seems to help is running fan with windows shut and floor vents shut. Any other combination and after a short drive my clothes smell like exhaust. Thought it might be blowby escaping from valve cover breather, rerouted that into air cleaner intake but to no avail. No audible exhaust leaks before the muffler. It's possible that there are some in the muffler and tailpipe that I have not discovered. Car was quite rusty, is it possible that it is coming from the end of the tailpipe back into the trunk? Don't want to spring for a new exhaust if it is not going to fix the problem. Thanks.
  2. cbarge
    cbarge World Famous Barge in a Budget FCBO Gold Member
    3,223
    3579
    Nov 22, 2010
    Kingston Ontario Eh?
    If you have holes in the trunk,or the trunk weatherstrip is petrified or missing you will get fumes in the cabin with windows down...Kinda creates a vacuum.
    Holes in the floor will do the same thing especially if the top of the mufflers have holes that you cannot see.
    I always run the end of the tailpipes 2-4 inches past the bottom of the rear bumper too.
    hope this helps
    • Agree Agree x 2
  3. 4spd300J
    4spd300J Member
    101
    55
    Jun 7, 2017
    Aztec, New Mexico
    As in the above post, any gap in the trunk seal will draw enough fumes in the cabin to make it seem like the exhaust comes out of the dash. That's why wagons ran the exhaust out the sides instead of straight out under the bumpers.
    • Agree Agree x 1
  4. The Goose
    The Goose Senior Member
    1,805
    2542
    Nov 21, 2016
    Santa Clarita ca
    Forget stinky clothes - this can kill you. You can smoke bomb the exhaust and check for leaks. We do that to check for leaks in cabs on heavy equipment. It’s not as big a deal today as back in the good ol days. Back then Rusty pipes cost thousands of lives. Be careful bud...
    • Agree Agree x 1
  5. 1970FuryConv
    1970FuryConv Senior Member FCBO Gold Member
    1,853
    1522
    Aug 8, 2014
    Richmond, VA
    If you suspect a plugged muffler, put a vacuum gauge on the intake and slowly increase engine speed. Vacuum will drop toward zero from an idle vacuum of around 17hg. Old mufflers can look OK from the outside but have a lot of rust from condensation on the inside.
    • Like Like x 1
  6. cbarge
    3,223
    3579
    Nov 22, 2010
    ...Or plugged by mice nests..
  7. Jack Ryan
    9
    0
    Apr 20, 2019
    Belvidere, IL
    Hey thanks all, gives me someplace to start, actually lots of places to start. Has not killed me yet, only a little dizzy.....kidding.
  8. cbarge
    3,223
    3579
    Nov 22, 2010
