Formal 440 Owners. Help.
commando1
Sebring, Florida
At the front of the intake manifold, is this right?
1. Does the spark plug wire bracket go on bolt #1 (as shown)?
2. Does the A/C bracket go on bolts #2 & 3 (as shown) or on bolts #1 & 2?
3. Does the A/C bracket face as shown (pointing towards the front) or the other way (pointing towards the rear)?
I'm stuck.........:soapbox:
Insert the word 'before'. Hook stuff up and see if it works.
Glenn
Unless someone else dismantled it years before and put it together so oddly you ask yourself if that was right in the first place. AMHIK
Look in your FSM , no reason to ask a technical question on the board....... Right?
Ask for help, get ballbusters - welcome to FCBO........
Did you do the following first? " You USE the books and then ask the questions where the books come up short.
No. Wait. Use the books, Google, and then ask questions. "
Give a man a fish and...
Dave is on fire. All I could think of when I read Stan's first post was to imagine the ball breaking I would receive if I posted that. From whom????
Yes. That's a 74 and up only a/c bracket. And thank you for offering unlike...
Here's a '73... looks to be the same. As for the plug wire bracket, I would put the distributor in and the coil on and the placement should be clearer.
Mike or Mr C would likely give some certainty to your situation.
Where you been?
:icon_rolleyes:...............:reading:
There used to be a guy here that looked up most everything, and would likely have a service manual for a Formal Chrysler.
Not sure, but I think his name was Stan... :eusa_think:
:busted: ...........................:laughing4:........... welcome back ....
