Compressed air.The original fuel and brake lines appear to be in good shape, from the outside. What do you guys use to clean out the inside?
What does the brake fluid look like in the booster? If it's clear it's ok but if it's foggy you should flush out. If in doubt, swap it out. Don't be cheap when it comes to brakes. Get a see through inline gas filter and monitor how the fuel looks and you'll be ok.
If you have brake fluid in the BOOSTER ....... You have a problem...
I would not use the see through filters.... They are either glass, which can brake, or plastic, which can melt. Either way gas will spill over your hot engine. (If it can happen, it will happen). A fram G15 metal can filter, or equivalent is a good choice
