Fuselage - Drums to Disc Brake Conversion
Commando, isn't that the factory ball joint separator tool? It has been 35 years since I've seen one but looks awful familiar.
Yep. In fact, mine is the the actual Miller tool spec'd out in the FSM. Found it on ebay.
WOW, all this work, and for what? I used the SSBC on my 300, got to keep the 14" wheels. Bolt on and go! The only thing I had to add was a 5/16" spacer to keep it from rubbing. Good Luck
I had to otherwise they'd rub the tire. SSBC was speechless as to why when asked about it.
Nope, Not goin to happen! I don't want to lose the spinners that are on there, that's why I went with the SSBC road, to keep the 14's.
no one here has ever separated a front end just using a big hammer? smack the rounded area of the steering knuckle where the ball joint pin goes through. same with the lower control arm, etc. might take a half dozen good whacks but should pop right out. seriously? no front end guys here?
I have. I didn't own a large pickle fork for a long time.
It's a matter of opinion what works better. I like the big hammer method myself, but this is his first time doing front end work. Most people have used a pickle fork and are familiar enough that we can walk him through it.
i don't own a fork and wouldn't bother. guaranteed ripped boot, but not guaranteed to separate the joint. teach him the pro way. there are videos dammit! (hard not to get excited. it's the easiest pro trick out there.)
Good point. You don't need to get too excited, I think we are all on the same page.... We just want to help Gary.
We'll give him some methods and see what he wants to do.
Nice! Having a mechanic friend must really come in handy at times I bet. I'm the only individual in my family who will spin wrenches, unfortunately. Hence, I pretty much do everything myself...all that I can that is.
Yes, it really is - was. When I moved here to Chico I put 6 hours between him and me.
But, we still talk on the phone and via Internet. I had a Missionary friend from South America need help on a pick-up last week. I couldn't diagnose his problem, so I gave him Chris' email. Chris did! That's a good friend, indeed!
And Im very grateful for all the different opinions on this; helps me to decide wut I should do cuase honestly I have no idea. Never did a drum to disc conversion before so its new thing for me. I have a line on some 73' C body spindles..so I think this is gonna happen.
I have, but don't like to. All I can think of is the possibility - albeit rare - of flaring the end of that threaded joint and then I'm in for some real hurt. I do not have cutting tools. Even so, I did do it on my T-bird when I rebuilt its front-end.
I bought a pickle fork attachment for my air chisel a couple years back. Works great on tie rod ends, but I haven't tried a ball joint yet. Anybody ever use one on a ball joint?
I use this for most all front end work when replacing parts, if I just have to remove something and don't want a torn boot I use a large hammer or the hammer for the air chisel
possibility of flaring the end of that threaded joint
doesn't involve hitting the threaded end of the pin. hit the side of the thing that the pin fits into. might hit the side of the threads if aim is real bad. gary, seriously, separating the front end parts is by far the easiest part of the conversion. wish i could show you, but there are videos. also, yes to factory parts. these guys have given you good advice. they're a great bunch.
