Thank you all. I was on the fence about blocking the crossover and this helped me make the decision. I will order a new pan and report back.
@david hill
I don't see any holes or cracks in the pan when I hold it up to a flashlight. Since I plan to replace the pan I am not going to worry too much about it. Although it is ironic the pan is rusting with so much oil covering it!
I will read up in the FSM but for those who have done it, should I use thread sealer on the intake manifold bolts?
Also, should I be concerned about the carbon build up around the crossover ports before I block it off with the new pan? If a chunk of carbon where to break off is it going straight back out the exhaust or will it possibly fall back into the cylinder and cause chaos?
@david hill
