Headers in Wagons
Mopar Wagons
  1. mag162
    mag162 Active Member
    309
    58
    Sep 26, 2017
    New York
    I have a 67 fury wagon with a 69 440HP motor in it out of a RR.
    I want to pull the HP manifolds off and install headers.
    What headers have fellow wagon owners installed?
    Part numbers?
  2. twostick
    twostick Senior Member
    2,286
    978
    Dec 13, 2012
    Beautiful Downtown Roebuck Ont.
  3. Mr C
    Mr C Senior Member
    4,038
    1772
    Nov 20, 2012
    All over
    What headers have I put on my wagon? That's an easy one...none!
    I don't have any burnt plug wires, or leaks either!
    • Like Like x 1
    • Thanks! Thanks! x 1
  4. 68 4spd Fury
    68 4spd Fury Well-Known Member
    937
    245
    Aug 17, 2014
    Syracuse, NY
    Not sure what you're after. I can't claim to be an expert but, everything I've read, the difference between the HP manifolds and even the best headers is negligible. Unless your serious racing and need that and that and the weight reduction. I'd stick with the HP.
  5. LeBaron1973
    LeBaron1973 Old Man with a Hat FCBO Gold Member
    6,108
    862
    Sep 13, 2015
    Harewood, Christchurch, Canterbury, NZ
    Agree, Nick's garage recently did a test and the Headers and HP manifolds were virtually identical- both much better than stock.
    Maybe save your money for something which will make a difference?
    Best wishes with your wagon whatever you decide.
  6. twostick
    2,286
    978
    Dec 13, 2012
    Not sure what video you saw but the one I saw showed 30+ horsepower difference between HP manifolds and headers.
    The one that was close was between Maxwedge manifolds and headers. Not quite the same thing. Reproduction Maxwedge manifolds are $1200. I have yet to find someone that can tell me they will fit a Cbody.
    Kevin
  7. LeBaron1973
    6,108
    862
    Sep 13, 2015
    Thanks Kevin, that's the one I was thinking of.
  8. CBODY67
    CBODY67 Old Man with a Hat
    5,987
    1364
    Mar 27, 2011
    Seems like I recall reading, back then, that the MaxWedge manifolds would not clear the power brake booster. But that was on the '62 cars, I believe?
    Just because the popular Brand X small block NEEDS headers on them, does NOT mean that the Chrysler HP manifolds (i.e., 440/375 and 383/335) are not any good. After all, the '90s Chevy LT1 350s, once you got past all of the three layers of heat shielding, had a slightly smaller version of the Chrysler HP manifolds hiding in there. IF GM went to the trouble to copy the Chrysler design, it must be good. Especially as they went to great lenghts to hide them under so much heat shielding!
  9. CBODY67
    5,987
    1364
    Mar 27, 2011
    After watching that video of Nick's a while back, I came away a bit underwhelmed. That particular engine did sound happier with the headers, but none of the combinations were optimized as to carb jetting and such. Might be good for a general test, but no data that I would desire to quote numbers off of, fwiw.
  10. Turboomni
    Turboomni Old Man with a Hat
    5,908
    3381
    Dec 14, 2015
    MA
    Maxwedge manifolds had problems heating up the master cylinder apparently. Most applications i saw pics of was a one reservoir master with no power brakes i guess to keep it out of harms (or heat's) way.
  11. commando1
    commando1 Old Man With a Hat on the Porch FCBO Gold Member
    35,271
    19769
    Mar 10, 2011
    FUHOA Reservation, Sebring, Florida
    I've given up this futile battle, Mr C.
    For every one you save from doing something totally stupid, 10 more come along and want to do it, too.
    I have quit trying to keep Humanity from dumbing down.
    • Like Like x 1
