Heavy Metal
The missing link between the General Dynamics/Grumman F-111B and Grumman F-14 Tomcat.
As previously discussed, the F-14 Tomcat was developed in the wake of the F-111B 'Sea-Vark' failure using largely the same concepts but packaged better.
In between, there were other contenders from the US Navy's VFX programme. One of those was the Ling-Temco-Vought (LTV) V-507 Vagabond. This was in effect an Americanized Dassault Mirage G, which was France's swing-wing fighter prototype.
The aircraft was designed to French specifications and needed major modifications to meet US Navy standards and requirements. By far, the biggest hurdle was perhaps the need to shoehorn the F-111B's Hughes AWG-9 radar and AIM-54 Phoenix BVRAAM combination into an airframe originally designed for smaller Cyrano series radars from what was then Thomson-CSF.
i have a list had the f111b as worse fighter bomber (McNamara trying to make armed fores commonize a fighter bomber design to save money) ever. i am sure smart people worked on it/, specified it but sandwiched between the f-4 and the F -14, (both bada****) it left much to be desired in comparison..
everything i ever read about it, the plane was more a bureaucratic failure as much much as it was a technical failure. one plane for the Air Force and Navy good idea ---- on paper. they just couldn't build it. perfect example of the cliche a camel is the result of a committee design of a horse.
maybe others with expert knowledge read it different. to me, it was a poorly executed "aardvark". i wasnt a taxpayer then, but im sure i would have ben torqued over it.:BangHead:..
i have alyea had the f111b as worth fighter bober (McNamara trying to make armed fores commonize a fighter bomber design to save money) ever. i am sure smart people worked on it/, specified it but sandwiched between the f-4 and the F -14, (both bada****) it left much to be desired in comparison..
every thing i ever read about it, the plane was more a bureaucratic failure as much much as it was a technical failure. one plane for the Air Force and Navy good idea ---- on paper. they just couldn't build it. perfect example of the cliche a camel is the result of a committee design of a horse.
I worked with guys (Hughes Aircraft Company) that had worked on the A-12 (fighter version of the ST-71) and F-106. I didn’t hear one way or the other regarding how the F-111B worked or not. However, they had a certain affinity towards the F-14, but that’s probably because they had spent so much time working in developing the weapons systems.
I think the adaptation for the Air Force and Navy created almost two separate platforms.
The F-111 Aardvark landed safely After struck a pelican at very high speed.
The strike occurred during high-speed, low-level flight, The bird was an Australian pelican, one of the heaviest flying birds, The impact caused major damage to the aircraft’s nose/radome and structure, The crew maintained control and returned to base
At low level, an F-111 could be doing 500+ knots. Kinetic energy scales with mass × velocity², so a pelican at those speeds delivers impact energy comparable to: a small motorcycle hitting the jet head-on, or a cannon round made of meat and bone.
yeah the big pelicans can weigh up to 40 lbs. and one thing about the f111 was fast. we all got a mass x acceleration lesson when a piece of foam took down the space shuttle. was there was also paint chip hitting the space station window - at 17,000 mph
Tiny Debris Chipped A Window On The Space Station Tiny Debris Chipped A Window On The Space Station
first boat? U.S.S. Defiant. i have no comment on class naming kerfuffle. look at futuristic proposed armament and propulsion. these are bada**es,: over 800 feet long, over 30 knots ... wow. guess who's coming to diinner?:poke:
USS Defiant (BBG-1) - Wikipedia USS Defiant (BBG-1) - Wikipedia
NameTrump class
Operators
United States Navy (projected)
Preceded by
Planned10 to 25
TypeGuided-missile battleship
Displacement>35,000 t (34,000 long tons; 39,000 short tons)
Length840–880 ft (260–270 m)
Beam105–115 ft (32–35 m)
Draft24–30 ft (7.3–9.1 m)
PropulsionIFEP Integrated Full Electric Propulsion
Speed>30 kn (56 km/h; 35 mph)
Crew650-850 personnel
Armament
as soon as i get excited - this aint my "grandfathers battleship"(Iowa below-powerful but stilll obsolete) - the way this thing gets deployed/defended has got to change. aint sure we can afford one, let alone 25 of them (at $20 Billion a piece) we need diffent, better submarines (Columbia-class_submarine and we want to put people on Mars. When do we (the country) go over all that?
https://news.usni.org/2025/12/22/tr...l-be-largest-u-s-surface-combatant-since-wwii
Google AI Overview
Battleships became obsolete due to the rise of air power (aircraft carriers), guided missles, and submarines, which offered longer range, greater flexibility, and better cost-effectiveness, rendering massive, slow, gun-focused ships vulnerable and inefficient. While they remained symbols of power, technology proved smaller, faster vessels with missiles and aircraft could deliver more destructive force more cheaply and safely, making large armored battleships relics of a bygone era.
Key Reasons for Obsolescence:
  • Rise of Air Power: Carrier-based aircraft could strike targets hundreds of miles away, far exceeding a battleship's gun range, and project power inland, making battleships less relevant for sea control.
  • Guided Missiles: Missiles provided a way for smaller ships (destroyers, cruisers) to deliver devastating attacks from great distances, bypassing heavy armor and making battleships vulnerable targets.
  • Submarine Threats: Advanced torpedoes and submarine technology made large surface ships highly susceptible to surprise attacks, as seen in WWII.
  • Cost & Efficiency: Battleships required thousands of sailors and immense budgets, while smaller, modern ships with advanced electronics and missile systems could achieve more for less.
  • Nuclear Age: The threat of nuclear weapons highlighted the danger of concentrating so much power in one large ship; it was better to disperse firepower across many smaller, more expendable platforms.
  • Inaccurate Bombardment: Even in WWII, their large guns struggled to hit camouflaged, far-off targets effectively, a job better suited for precision-guided munitions from aircraft or missiles later on.
Relevance
** Sea Control:** Carriers need air superiority and struggle to control contested sea zones long-term; battleships can deny areas to enemies, acting as floating fortresses.
** Firepower:** Massive guns provide overwhelming firepower for coastal bombardment, a role difficult for air power to replicate with the same sustained force.
** Armor:** Thick armor makes them highly resistant to many modern threats, especially missiles designed for lighter ships, though vulnerability to specialized anti-ship missiles remains.
** Symbolism:** Battleships are potent symbols of national power, influencing morale and diplomacy.
The Final Era:
  • Even though obsolete in concept, the US Navy kept powerful Iowa-class battleships active until 1992, using them for shore bombardment and as powerful symbolic deterrents in conflicts like the Gulf War.
  • Ultimately, technology made the battleship's core function—delivering massive firepower—achievable by other means, ending its reign as the dominant naval weapon.
Why won't these things still be $20Billion apop sitting ducks to the adversaries subs/missiles?? i can't find a good answer or maybe I'm too stupid.
This is the type of stuff that I worked on during the second half of my career. (But not this specific one)…
“Rivet Amber” was not this aircraft’s only nickname; she also went by “Lisa Ann”. She was a very special aircraft and was the most expensive aircraft in USAF inventory until the B-2. Her radar system alone cost $350M in today’s dollars.
The green ring around her fuselage is composite material, and houses a 7 megawatt phased array radar that weighed over 35,000 pounds. If you look closely under the wings, you’ll see what appear to be a 5th and 6th engine between the inboard engines and he fuselage. One of these is a Lycoming T55 jet engine that powers the radar; the other is a heat exchanger to cool the radar.
Boeing RC-135 - Wikipedia
On the night of August 19, 1980, Saudi Arabian Airlines Flight 163 lifted off from Riyadh under calm skies, carrying 287 passengers and 14 crew members. A routine short-haul journey quickly turned into a silent struggle when a fire erupted in the rear cargo hold. The blaze remained largely invisible at first, yet its smoke began to creep through the cabin, wrapping the passengers in a haze of toxic peril. Inside, there was confusion and fear, as ordinary conversations and laughter were slowly swallowed by the advancing smoke.
The captain executed a textbook return to Riyadh, landing the massive Lockheed L-1011 TriStar with precision. From the outside, the plane seemed unharmed, its wheels rolling along the runway as if nothing had gone wrong. But inside, the cabin had become a sealed chamber of peril. Smoke thickened, oxygen thinned, and the minutes stretched into a torturous silence. Rescue teams stood ready, unaware that evacuation was not being ordered. By the time the aircraft doors were opened, all 301 aboard had succumbed - not to impact, but to asphyxiation, a silent tragedy hidden behind the façade of a safe landing.
Flight 163 remains one of the most haunting reminders that safety in aviation extends far beyond landing. The incident prompted global reforms in fire detection, emergency evacuation protocols, and crew training, ensuring that no landing would ever again be futile. Survivors and industry experts alike reflect on the courage of the crew who maintained composure in the cockpit, the resilience of passengers who tried to adapt to the smoke-filled cabin, and the painful lessons learned about the limits of human endurance when critical procedures fail. It stands as a sobering testament to vigilance, preparation, and the silent dangers that can turn ordinary journeys into unimaginable tragedies.
Saudia Flight 163 - Wikipedia
Over ten years (March 8,2014) since it happened and a company announces they will start the search again. Maybe some of yall remeber the loss but especially the search (the pings in the Indian Ocean).
They either find it and collect 70 million dollars or they get nothing. i surely feel sorry for the 239 people (and their families) lost. Hard to believe somebody (malaysia govt?) is stilll willling to pay that much a decade later. Ther'se a story there but it eludes me.
I think it the most credible data say it crashed in the Indian Ocean. Dunno why but doubt any other story. Will they find it? Well Bob Ballard finally found the Titanic but it took 70 years. Granted, our search equipment/technologys are much better but still as I understand what they tried ten years ago was pretty good and the Indian ocean is stilll big(the plane was BIG too (boeing-777 a Boeing 777) and deep.
Hood vs the Bismarck.
May1941, the H.M.S.Hood Admiral-class_battlecruiser (our Iowa class boats were still on the drawing board) this biggest, baddest battlewagon on the planet. the Nazi Germans built something better and the Brits had to find it and sink it. 3 says later they did it. https://www.hmshood.org.uk/hoodtoday/2001expedition/hoodt
Hood: 1916, 860 ft long, 32 knots, 45,000 tons, 150,000 horsepower, relatively lightly armored
Below: Bismarck, 820 feet long, 30 knots, 40.000 tons, 110,000 horsepower, big guns, heavily armored
I wont bore you folks with the whole story (its here Battle_of_the_Denmark_Strait) but both those magnificent heavyweights battled in the Danish straight in 1941 Germans. the Bismarck, allegedly via a lucky shot won that encounter killed over 1,400 British sailors and sunk the Hood. the British led the susequent search on destroyed the Bismarck later.
The whole story, and the video is quite long but complete. It gives creedence to the context of these ships, the nationalism of Britain and Germany, the tremendous , gruesome loss of life on both sides, etc., and gives new meaning to "war is hell" phrase . Also this fight was the genesis of the debate we are having 90 years later about the effectiveness of the battleship as a war weapon. The equipment the British use to kill/sink the superior Bismarck was astounding.
I binge watched the History Channel (youtu.be/Z7EvnYZAW8?si=fDBZqYP9c7Rhmvd2) series and it was fascinating. sits in two pieces in 9300 feet of water, blown to bits cuz Germans shelled the rear magazine blowing in half and sinking it in 3 minutes. 3 days later took basically took their entire Navy and the Brit found her and sunk her.
I wont bore you folks with the whole story (its here Battle_of_the_Denmark_Strait) but both those magnificent heavyweights battled in the Danish straight in 1941 Germans. the Bismarck, allegedly via a lucky shot won that encounter & killed over 1,400 British sailors and sunk the Hood. the British led the subsequent search on destroyed the Bismarck three days later killing thousands of germans.
Between 1978 and 1980, 650 M48A2CG of the German Bundeswehr were upgraded with the 105mm L7A3 maingun, Commanders cupola, AntiAircraft MG3 and other components of the Leopard-1 and received the new and rather clumsy designation M48A2GA2. The maingun was mounted in a distinctive shaped gun mantlet and the original travel lock on the rear engine deck had to be replaced with a new version.
The M48A2GA2 was retired from the German Bundeswehr in 1991 and most were subsequently scrapped.
The french were prretty mechanical to do in the mid 50's. Nord Gerfaut.
General characteristics
  • Crew: 1
  • Length: 11.39 m (37 ft 4 in)
  • Wingspan: 7.5 m (24 ft 7 in)
  • Wing area: 26 m2 (280 sq ft)
  • Max takeoff weight: 5,380 kg (11,861 lb)
  • Powerplant: 1 × ATAR 101G afterburning turbojet, 31 kN (7,000 lbf) thrust dry, 44 kN (9,900 lbf) with afterburner
Performance
  • Maximum speed: Mach 1.13 at 10,800 m (35,400 ft)
  • Service ceiling: 15,400 m (50,500 ft)
The EFW N-20 Aiguillon (Stinger) was Switzerland's first indigenous jet fighter project, developed by the Swiss Federal Aircraft Factory after World War II. It featured a unique tailless design with four turbofan engines buried in a swept delta wing and was intended to carry a detachable weapons bay for rapid rearming. Although a full-scale prototype was completed and performed taxi tests in 1952, the project was cancelled in 1953 due to engine development issues and high costs, leaving only a single non-flying prototype today.
EFW N-20 - Wikipedia
The Blohm & Voss BV 222 Wiking was a massive German flying boat developed during World War II. It was the largest Axis aircraft of the war and one of the heaviest aircraft ever flown at the time. Designed for long-range maritime patrol, transport, and bomber roles, it was intended to support operations across vast oceanic distances, but only one prototype was completed and flown.
Blohm & Voss BV 222 Wiking - Wikipedia
View attachment 750423View attachment 750424
i dont know my aerodynamics well enough so i was trying to understand how/why one would design out horizontal stabilizers (no tail)? i get "how" they work ( how you do aerodynamic maneuvers without them but "why" eludes me.
they obviously work but seems like the wings (and sophisticated controls) do multiple tasks. there must be some benefit but clearly most designs have '"tails". must be a good reason for that?
i found this short video and concluded oversll fixed tails are better.
The flying wing aircraft requires constant adjustment of the control surfaces. I find it amazing that the YB-35 and YB-49 flew with mechanical or manual (pilot) controls.
