Have you have the engine on a dyno?
If you did, what kind of power does it make?
No, I didn't bother dynoing this one. I'll dyno it at the drag strip. :woot:Have you have the engine on a dyno?
I'm shooting for mid 11s but it's too early to tell. I have to scale the car yet and do a bunch of other stuff. I'll keep everyone posted.Great! Let us know what your ET and speed is.
What do you estimate your ET will be?
Mid 11's is ambitious, the car will need a diet. I don't remember but are you running nitrous or all motor? You will need 500+ to get in the 11's. I wish you the best. Can't wait to read the updates.
Stock bottom end smog 440 with port d 516 heads Victor intake 850 demon carb and a .509 cam made 588 hp IIRC. It can be done.8.2 comp. is going to be hard to get around to make any good power.
8.2 is what it was with factory heads. My heads are 75cc. I've made plenty of power with pump gas and 9.X:1 over the years. This engine will make good power. Not John Force power but plenty of power for a daily driver.
Love it!This thing will hook on wet grass.
I don't know where you are in Wisconsin, but are you going to attend Mopars in the Park in Farmington June 4-5? I'd love to see that beast in person!Update:
I gave up on the headers I had. I broke down and called TTI. Should have done it right the first time. Engine and trans is in the car but I have to make a transmission mount. I have a couple of mounts and neither one works. The mounting point on the new transmission is in a different location than the stock 65 transmission. Then a bunch of piddly **** like fuel pump, fuel line, trans cooler lines, shifter, gauges, blah blah blah. Hoping to have this beast out in 3-4 weeks.
