If the radiator needed to be cleaned out, so might the coolant passages in the block. With the age of the car, probably time for some new freeze plugs not too far in the future, usually. Presuming the thermostat is a 180 degree F model?
Is the heater working well? If you use a flush solution in the block prior to the freeze plug replacement, DO change the heater hoses to delete the heater core from the circuit. Reason? The same flush which will remove any accumulation from the engine block passages can also remove any scale in the heater core, which might then LEAK. So taking the heater core out of the circuit can prevent this. Unless you are getting ready to replace the heater core anyway.
In the mean time, verifying the base ignition timing is good to do, INCLUDING checking to see if the vac advance is working. You can also check the engine temps with an IR heat gun, too, to verify the temp gauge reading.
If the temp gauge needle is maybe two-needle widths past the center mark, no problems, but do verify that the timing is correct.
Just some thoughts and observations,
