traintech55
Yep, you only do that once.Learned a lesson, didn't you?
You lived... quit your bitchin'.View attachment 152846 Yep, about a month ago when I was down at his place picking up my 300. We walked into his shop to look at a car he was working on that had a MSD ignition on it. Wollfen said aye mate grab hold of that wire for a bit. I said no problem bud as he walked around to get in the car. So I'm holding the wire & looking where it go's and about the time I see the other end is attached to the MSD coil that has a sticker on it that says 40000 VOLTS he turns the key & I start dancing. Yelling , smoke comming from my ears, lighting bolts comming out of my hands & flying all over his shop. Wollfen gets out of the car & says thanks mate. I guess the coil is good after all. The charge burned a small hole in my finger where it entered me. I felt it up in my chest & my heart rate was clearly higher & I was winded. My finger still has the hole in it & is still sore to the touch.
Oh he's been paid. After he tried to kill me I paid the entire bill in cash.You better start paying him Bob, I would hate to see what he will do to next
Sure did. Wollfen means "wise guy" in AustraliaLearned a lesson, didn't you?
Works really bad when your zipper is the path to ground... but IS fun to watchLesson learned.... do not lean over and make contact with the fender while disconnecting plug wires on a runing engine.
No doubt, Wolfen meant well.
No doubt, Wolfen meant well done.
You nearly succeeded. You should have had me standing in water.I had nothing but the best intentions.
He is shocking once you get to know himnot only does Gary do great body work, but he has an electrifier personality.
