1969 383 mate up to a 1964 727?
  1. MericaMopar
    MericaMopar Member
    58
    10
    Dec 17, 2020
    Merica
    Would a 1969 383 mate up to a pushbutton 1964 727 torqueflite that's currently on a 361 without any issues? I heard there were changes to the trans or torque converter for 65+ (if that's even true).
  2. mikedrini
    mikedrini Well-Known Member FCBO Gold Member
    565
    285
    Oct 9, 2017
    Center Barnstead, NH
    I have a 1973 440 mated to my 64 Push Button T/F and prior to that I had a 1967 383 bolted up to it, so that should work. There were changes to the 65 T/F moving forward, mostly in regards to the spline on the input shaft (went from 19 to 24 I think?), throttle linkage, parking cable, just to name a few.
    • Thanks! Thanks! x 1
  3. 413
    413 Well-Known Member
    993
    303
    Jan 28, 2019
    NW USA
    If you use the converter from the 64 trans it will fit just fine.
    Converter spline and input size changed in 1967.
  4. MericaMopar
    MericaMopar Member
    58
    10
    Dec 17, 2020
    Merica
    Thanks guys
