1972 Fury III
71ChargerSE
North Richland Hills, Texas
Traded this car for 400/727 that I bought for my Charger. She's a bit rough around the edges, and the carb needs to be rebuilt, but its complete and she runs.
Fender tag, mostly decoded
PH41:
Plymouth Fury
High
4 Door Sedan
M2D: 400 190HP(net) 1-2BBL 8 CYL
1972
Belvidere, IL, USA
293308: Sequence number
E63: 383 cid 4 barrel V8 H.P. 335hp
D34: Light Duty Automatic Transmission
GY9: Dark Gold Poly Exterior Color
D4Y5: Trim - Luxury, Vinyl Split Bench Seat, Unknown Color
GY9: Dark Gold Poly Int. Door Frames
519: Build Date: May 19
456318: Order number
V1W: Full Vinyl Top, White
U: USA Specifications
G11: Tinted Glass (all)
G31: OS RH Manual Standard Mirror
H51: Air Conditioning with Heater
L25: Trunk Lamp
L31: Hood/Fender Mounted Turn Signals
L42: Headlamp Time Delay
M15: Unknown
M85: Front & Rear Bumper Guards
N88: Auto Speed Control
R21: AM/FM Radio (5 1/2 Watts)
V5V: Body Side Stripes, Orange
26: 26in Radiator
END: End of Sales Codes
Can anyone decode the few "unknown" codes?
Post some pics in a few.
Wait, the M code is for the 400, which you listed. Then you said 383...... being a 72 its a 400
I did not notice that, I copied the decode from another site.
The guy I got it from couldn't bring himself to part it out, and he wanted a motor for his '57 Desoto.
There was a local garage that bought a 72 Polara 2 door in similar condition from a auction. He wanted sixteen hundred for the car, not a straight panel on the car...... Yours looks better but still probably not worth an investment
OH ok the other pictures loaded while I was typing, I'll just say it ........part it out. Glad you are safe...
I wasn't going to restore, I'm just going to drive it. I'll get some tub and tile clear silicone and fill that little hole.
He did turn me on to a 69-71 Imperial coupe I have to go over and look at, after I replace the trailer tires and install my winch.
Thanks, the tires looked a little weather checked, but I didn't realize how bad they were. Trailer is only a year old...
The trailer is a year old, tags just expired. They are some really cheap tires, I replaced one last year when I snagged it on a gate hinge, 8'6" trailer, 9' opening. That tire looks great, the 2 remaining tires are worn and weathered.
After checking it over more throughly, I'm going to part it out.
Trunk lid and hood, along with both bumpers and the left grille are pretty much junk. I've already had an inquiry on the motor and trans, but the rest is up for grabs.
I could use a few things. Rear side marker lights, right front turn signal, and a few items under the hood.
