I would have to check the depth of ram.......
Artillery reference......Redleg's would understand.
Still trying work it out BobGary, did you ever figure out what is wrong with your car? LOL!
Anyone else have these problems too? I think this is what might be happening to me.
http://www.ceautoelectricsupply.com/hitempcovering.html
The description (2nd paragraph down) is almost dead on. 9 times out of 10 this is exactly what occurs. Its never been a problem before, but b/c the terminals on the mini starter do not locate in the same position as the stock starter terminals they brings the cable a bit closer to the exhaust manifold.
Negative. It'll turn over right now.....and It started yesterday. I can't take it out until I'm sure its dependable again. This is what's driving me bananasBut your car wont start right now correct? Without the heat....?
Yeh...this is absolutely maddening. I can go out there right now and it'll turn over without so much as a whimper.....and still there's that weird "click" noise somewhere in the dash when the key is turned and won't start (its not the solenoid, that can be heard also at the same time).Gotcha ....... Hard to diagnose a problem when it comes and goes and is playing hide and seek....
Good thought though in your link, I would have never thought
Well, bear with me. I was just out in the garage.Trying to approach this methodically and sanely. Battery & cables.Gary, the only thing left to do is this.
With the wiring diagram in hand, start the car and let it run.
Under the hood, push, pull, jiggle and wiggle, every damn wire under there. Wires, connectors, junctions, EVERYTHING, and see if you cant' get the car to die.
If not, repeat, under the dash. EVERYTHING. See if you can make it die.
There's nothing else you can do except drive it off a cliff...
I want to believe that too...cable/heat related.The battery voltage is important... but more important is the voltage at the starter.
I really think this is cable related. You've even just talked about the closeness of the cable to the manifold. With extra heat comes resistance.
You can check the wire resistance with a DMM but you will need to disconnect both ends so you aren't getting some sort of backfeed from the starter. Do both cables.... Battery to starter and battery to engine block.
Well, there's your problem LOLWell, bear with me. I was just out in the garage.Trying to approach this methodically and sanely.
I was thinking maybe a disturbance in the force....Well, there's your problem LOL
Seriously, I understand the frustration.
Now we have to start with the irrational stuff.
What phase is the moon in when it happens...![]()
Ya might want to take a lunesta tonight.....shop is closed for the evening. First (or second) think in the morning.Gary, humor me. We're running out of options.
Take a voltage reading at both sides of the fusible link. Should be the same of course.
Now stretch it hard and take a reading. Is there a voltage drop?
Or, heat up the fusible link with mama's hair drier on HI. Take a reading.
I need to know or I won't sleep tonight...
