SOLD 318 4 barrel intake
C Body Bob
Youngsville, NC
Feedback: 24 / 0 / 0
Ok all you 318 guys that have been wanting to upgrade to a factory 4 barrel intake. Here ya go. This is the 78-80 intake that was used on 318 Engines. Couple of notes. If using this on an older LA (small block) 318 it has an EGR valve on it. You can elimate this easily. I always cut a piece of steel & a piece of asbestos gasket or something heat resistant. Last for years. Also this intake has the smaller water neck that is off set. So your stock upper radiator hose won’t fit without a reducer or better yet a different hose. And the heat crossover passage is clogged up as per usual. It will need to be cleaned out for proper cold start performance. $100 plus shipping from Youngsville, NC
