Amp meter bypass for 1967 Imperial
Imperial
  1. MERNJ
    MERNJ New Member
    26
    29
    Feb 4, 2020
    Westfield NJ
    Re 1967 Imperial: How many of you out there did the Amp meter bypass whereby u run a 12 gauge wire from the alternator to the starter block incorporating the appropriate fuse link.
    Cuts the current running through amp meter dramatically and effects amp gauge needle "norm". My apologies if previously discussed. Any possible suggestions?
  2. mrfury68
    mrfury68 Senior Member
    1,262
    460
    Jul 15, 2015
    Bethel Park PA
    I did this on my Fury. You are not completely bypassing the alternator gauge just cutting the amount of current going through it. You are correct to use a fusible link. I also cleaned the terminals on my bulkhead and replaced some questionable looking terminal ends. This is a vital upgrade for our 50 plus year old cars.
  3. detmatt
    detmatt Old Man with a Hat FCBO Gold Member
    25,777
    11733
    Nov 14, 2010
    I haven’t yet but I need to.
  4. polara10x500
    polara10x500 Member
    62
    29
    Jan 26, 2020
    TN
    Go to forums tab click on electrical & ignition, its still on first page, very well done thread with pics. Can't stress enough importance of this electrical upgrade as most do on this forum. Would hate to smoke an fry my dash or completely burn my classic mopar to the ground. FIRE FIRE FIRE,, ops too late should have listen to these guys. Good luck, it's easy and very affordable.
    • Agree Agree x 1
  5. mopar440
    mopar440 Well-Known Member
    648
    182
    Oct 17, 2018
    St paul
    I have on all my cars, however I used a 40 amp fuse
  6. MERNJ
    MERNJ New Member
    26
    29
    Feb 4, 2020
    Westfield NJ
    Thank you Thank you
  7. Luke Pokrajac
    Luke Pokrajac Member
    150
    91
    Sep 2, 2019
    Rock Hill, SC (Charlotte Metro)
    Where did you all get the fusible link to do this bypass. I really need to do this on my Fury... Almost bought 10 gauge wire to do it yesterday.
  8. polara10x500
    polara10x500 Member
    62
    29
    Jan 26, 2020
    TN
    Lucky the day I went to NAPA and after the salesman telling me thay had no more fuseable links I found on the hangers two 14 gauge fuseable links behind some other shit. Showed them to the salesman and said you should learn your inventory he just grinned like he could give a shit an went right back to his cell phone. You have to take time an look, these people in these auto parts stores are robots. Now if you have a store that you trust and know people that's great but you have be carefull who you buy from these days. I bought both of those links because I can't find them anymore. American made eletricals. Did my bypass surgery on the amp gauge an all is good now. Good luck.
  9. polara10x500
    polara10x500 Member
    62
    29
    Jan 26, 2020
    TN
    Sargent Carter say's Move it move it move it! I say DO it! Do it! DO IT!.....
  10. CBODY67
    CBODY67 Old Man with a Hat
    6,026
    1373
    Mar 27, 2011
    We used to stock fusible link wire at our back parts counter. It was on a small roll. Seems like we had two different gauges, to match what GM used in their harnesses. Maybe 10' to a roll?
  11. live4theking
    live4theking Old Man with a Hat
    10,700
    2941
    Nov 24, 2014
    Rockland; Venango County Pennsylvania
    I bought a 10' roll from the local parts house to do mine.
  12. Richard Reau
    Richard Reau Member
    186
    135
    Jun 12, 2019
    Tampa
    I opened up the dash and took both wires off the ammeter and bolted them together, and then taped the crap out of them. Then, I also pulled a new wire from the alternator, through a 12" piece of fusible link wire ($15 at the auto electric shop), and in to the starter relay. Both of these ideas came from the forum somewhere.....
    I then put a lobe-sensing pertronix kit in my distributor, and using their coil I eliminated the ballast resistor on top of the engine. Come to think of it, when I did the ammeter bypass, I also eliminated the ballast resistor on the firewall near the booster. I'm sure someone is gonna tell me that's wrong, but 1.5 years later, the car runs perfect with no electrical issues or ignition issues or lighting issues or charging issues whatsoever.
  13. RagTop66
    RagTop66 Member
    164
    113
    Sep 1, 2014
    Pennsylvania
    I did. Super easy and great insurance against setting your dash on fire.
