How do i remove the oil pan on a 1968 New yorker
Early C Bodies - The Slab Side Years
  1. scott cacciamani
    scott cacciamani Member
    67
    5
    Aug 13, 2019
    new york
    Hi, I'm new here. I was just wondering what the best way to remove the oil pan on a 1968 New Yorker?
    Thanks
  2. Snotty
    Snotty Senior Member FCBO Gold Member
    3,178
    1095
    Aug 18, 2015
    Chico, California
    With tools.
    :lol:
    Just kidding; welcome!
    I know someone will come on here and tell you. Never done it so I cannot.
  3. GJS
    GJS Senior Member FCBO Gold Member
    4,383
    2335
    Aug 10, 2016
    Connecticut
    Engine and exhaust set up?
  4. cbarge
    cbarge World Famous Barge in a Budget FCBO Gold Member
    2,592
    3175
    Nov 22, 2010
    Kingston Ontario Eh?
    Drain engine oil.
    Undo motor mounts.
    Undo stwering linkage fron idler arm and pitman arm.
    Jack up motor.
    Remove oil pan
    • Agree Agree x 1
  5. bigmoparjeff
    bigmoparjeff Senior Member
    1,234
    898
    Aug 9, 2017
    Dublin, PA
    Do you need to jack up a big block to get the pan out?
    I thought that it might just squeak out once the center link is out of the way.
    May depend on single or dual exhaust? Dual = no jacking, single = engine has to go up a bit.
  6. GJS
    4,383
    2335
    Aug 10, 2016
    Connecticut
    As cbarge says, drop the steering linkage.
    Drop the Y pipe if you have single exhaust.
    Remove trans inspection plate.
    You don't have to raise the engine. It's tight getting the bolts out at the cross member but it can be done.
  7. scott cacciamani
    67
    5
    Aug 13, 2019
    new york
    Thanks, i was hoping there may be a trick, but looks like the y pipe and steering linkage it is. Hate to go at those exhaust studs. Maybe i'll wait till i get a dual exhaust and do it all at one.
    thanks again
  8. GJS
    4,383
    2335
    Aug 10, 2016
    Connecticut
    Mine came off pretty easily at the flanges after a good PB soaking. .. my car is from TX though so. Popping one at the flange isn't as bad as busting one off in the head, either way.
  9. Snotty
    3,178
    1095
    Aug 18, 2015
    Chico, California
    I just removed the exhaust from a 2000 Chevy S 10; a lot newer than your '68 C Body. I had one bolt break. Be careful and good luck.
  10. boltupal
    boltupal Active Member
    277
    21
    Apr 3, 2013
    It might be safer cutting the exhust pipes then re weld them. Breaking a manifold stud will suck.
    • Disagree Disagree x 1
  11. cbarge
    2,592
    3175
    Nov 22, 2010
    The nut and bolts at the exhaust flanges dont worry about them.
    Not like a chebbie.
    On mopars I like the fact you can break them off or torch them off and use new hardware.
    • Agree Agree x 5
    • Like Like x 1
  12. swisherred
    swisherred Well-Known Member
    962
    464
    Jan 19, 2016
    winston salem, nc
    I lined the area around the bolts in aluminum foil and torched them off in just a few minutes...hope you dont break yours though.
  13. scott cacciamani
    67
    5
    Aug 13, 2019
    new york
    I'll put the heat to them and see how it goes.
    thanks scott
  14. live4theking
    live4theking Old Man with a Hat
    8,463
    1916
    Nov 24, 2014
    Rockland; Venango County Pennsylvania
    Let us know how it goes. How about some pictures of your car.
  15. scott cacciamani
    67
    5
    Aug 13, 2019
    new york
    It's my step sons and i will post some. Unfortunately, he had a slight accident this morning. smashed his original paint hood and original radiator. sucks
    thanks scott
  16. live4theking
    8,463
    1916
    Nov 24, 2014
    Murray B Park in Ohio can help with the parts if you can not find them closer. How is the grill?
  17. scott cacciamani
    67
    5
    Aug 13, 2019
    new york
    Grill is ok, small bent on the driver fender, motor mounts did not break so i'm not sure how the fan hit the radiator. I'll have to give it a good going over tomorrow. I will post a photo of the car later. Not a bad a bad looking car. What color is yours?
  18. SA67NEWPORT
    SA67NEWPORT New Member
    20
    1
    May 12, 2019
    RI
    I have a dark green 68 New Yorker for parts if I can be of some help, just let me know
    Steve
  19. live4theking
    8,463
    1916
    Nov 24, 2014
    Awe for petesake I think it is called, Frost Green. Previously I had one that was Mist Turquoise Metallic, I liked this color better.
  20. scott cacciamani
    67
    5
    Aug 13, 2019
    new york
    thanks Steve: He's going to need a hood. I can't fix it. shipping alone will kill him. I'm in staten island ny.
    scott
