RE: {Chrysler 300} Re: 1957 gas cap and tank venting .
Hi , I think you have that backwards— 57 requires vented cap , on dodge at least . Someone had put a non vented , on mine , way back in 1960 . It “ ran out of gAs” or “ frozen gas lines” —-all this bs ( hey it always started up after heating lines or new gas) . Caused by a vacuum in tank ! Which slowly fades out as you fix — anything!
I found out doing “ stuff “ in the woods ( Bob Segar) one winter night idling a long time , all of sudden Big Bang behind car, I jump out thought someone out there hit the trunk lid . Kind of scared !!I go to drive away car stalls = Yow !
By then I had gas in can in trunk over this stupid repetitive problem and no $ to fix it anyway .
So I get the gas , open gas filler , huge whoosh inwards but also big bang , as gas tank snapped back out . Aha
So yes , no gas tank vent on car in 57 , only .060 hole in cap .
The internal or external pipe you see on gas fill neck only vents air back into top of gas filler pipe as you fill tank , has nothing to do with this overall tank air vent ( and also does not work well (!) —thus the big spill out all the time with auto fill ) .
Jg
