I've tried to fix the poor idle on my 68 Fury III 383 auto. 2 barrel. Also has slight miss when I first start up. That seems to go away later as engine heats up. Car still accelerates well...goes like a raped ape when I stomp on it from stand still. I've checked all the plugs...cleaned and gapped them...checked wires/firing order...looks to be correct. Cleaned and gapped the points .017"...re-timed to 7.5 BTDC as the manual states. Tried adjusting single air mixture screw on 2 barrel Carter...strange left handed thread hmmm. I'm use to screwing in all the way until the engine wants to die then back off ~ 1 1/2 turns to smooth out but it doesn't work this way. All the way in seems to reduce shaking the most. Can't back it off from all the way in without making it shake worse. Increasing idle seems to mask the problem which is how it was when I bought the car. I've checked for vacuum leaks by spraying around base of carb...top of intake...checked hoses...Can't seem to find any. I disassembled carb. today and found all 4 mounting nuts/bolts loose plus a lot of rust sediment in bowl. I thought that was it! After Cleaning all that out...checking float for holes...finding none...blowing out carb. the best I could...checking float level per old carb. rebuild diagram I had...seemed fine and then installing new fuel filter...same problem was still there. Anyone have any other ideas??
Thank you, Bob
Thank you, Bob
