Convertible pump fluid?
Early C Bodies - The Slab Side Years
  1. TerryM
    TerryM Active Member
    333
    881
    Jun 18, 2016
    Brisbane, Australia
    Hi, just wondering what fluid ppl use in their convertible top pumps? Also does anyone know the correct procedure to bleed the system? Everything is brand new. Cheers Terry
  2. bluefury361
    bluefury361 Old Man with a Hat
    13,133
    9595
    Mar 9, 2011
    Alabama Gulf Coast
    Older units used brake fluid. That changed to trans fluid some time in the 60's. Best to consult your FSM.
    The system is bled by cycling the top down and up until it works as it should.
    • Like Like x 1
  3. Pete Kaczmarski
    Pete Kaczmarski Senior Member
    2,476
    1573
    Oct 11, 2012
    Waupun WI.
    I use ATF on my '62 300 convertible. Easier to clean up and won't eat your paint up. Open the fill screw slowly and listen for air escaping.
    • Like Like x 1
  4. rkrochen
    rkrochen Well-Known Member
    851
    631
    Jun 29, 2015
    Teulon, Manitoba
    Mine has brake fluid in it. Work the top up and down and it should clear the air out, keep checking the level. As some have said newer cars used trans fluid. Check to see if there is any fluid in yours and use what’s in it now don’t mix them.
  5. Evan Jansen
    Evan Jansen New Member FCBO Gold Member
    33
    8
    Jul 6, 2018
    Tustin, CA
    Good Morning
    My 66 uses transmission fluid. There are kits for refilling available that make it less messy. But I can also find and scan the instructions to you if you wish.
    • Like Like x 1
  6. Fury440
    Fury440 At my age everything's a good idea
    2,640
    2044
    Jan 15, 2011
    Calgary, Alberta
    G'day!
    I've used power steering fluid and transmission fluid in different convertibles and both work just fine. I steer away from brake fluid because the roof hydraulics seem to be prone to leaks and brake fluid is bad news on painted floor pans and even worse under rugs.
    To fill and bleed the system, remove the fill plug found on the pump reservoir an fill with the oil you decide to use. Fill to the bottom of the threads, I use a turkey baster. make a tin foil tray to sit under the fill hole to catch drips. replace the plug but leave it loose enough to pass trapped air. Cycle the top up and down. Check the fluid level against the threads and if required top it up and repeat the top cycle. You get the idea!
    Your car is amazing!!
    • Like Like x 2
    • Agree Agree x 1
  7. rags
    rags Senior Member
    1,044
    607
    Dec 14, 2015
    greater norwich metropolitan area
    dextron 2 in my '69 newport. NO brake fluid.
    • Like Like x 1
  8. CBODY67
    CBODY67 Old Man with a Hat
    5,300
    1210
    Mar 27, 2011
    IF the seals are new, then check with the seal provider to see what fluids they might be compatible with. Then go from there. On an un-rebuilt factory system, then the FSM recommendations would be operative. Brake fluid was OEM with many brands up into the later 1960s, as brake fluid was "everywhere" as atf was not, in the earlier years.
    The old Dexron II fluid is long gone, replaced by the current Dex VI, which is semi-syn. Dexron IV fluid is still around, as "multi-make" with GM vehicles being listed on the bottle as the main application. Other "multi-make" atf is related to import brands, fwiw. Check the ACDelco chemical/fluid products, too.
    • Like Like x 1
  9. TerryM
    333
    881
    Jun 18, 2016
    Brisbane, Australia
    The whole system is brand new. I’ll try and find the supplier. Thanks for your reply:)
  10. TerryM
    333
    881
    Jun 18, 2016
    Brisbane, Australia
    Thanks mate :)
  11. TerryM
    333
    881
    Jun 18, 2016
    Brisbane, Australia
    Thanks mate :)
  12. TerryM
    333
    881
    Jun 18, 2016
    Brisbane, Australia
    Thanks mate. Mine is all brand new and never filled. Although I did check an old spare set I had which looked like atf fluid
  13. TerryM
    333
    881
    Jun 18, 2016
    Brisbane, Australia
    Thanks mate that would be awesome :)
  14. TerryM
    333
    881
    Jun 18, 2016
    Brisbane, Australia
    Thanks mate:)
  15. TerryM
    333
    881
    Jun 18, 2016
    Brisbane, Australia
    Thanks mate :)
    • Thanks! Thanks! x 1
  16. TerryM
    333
    881
    Jun 18, 2016
    Brisbane, Australia
  17. rkrochen
    851
    631
    Jun 29, 2015
    Teulon, Manitoba
    You should be ok with atf, it’s a low pressure hydraulic system and as long as you don’t mix it you should be fine. It wouldn’t hurt to double check with the manufacturer of the seals and pump but I have a feeling it would be ok.
    I used brake fluid because there was a mix of fluids in there, probably atf and brake fluid so it didn’t work properly. I checked the manual and it said brake fluid so I flushed it out and went with the brake fluid. It’s been fine ever since.
  18. detmatt
    detmatt Old Man with a Hat FCBO Gold Member
    25,228
    11209
    Nov 14, 2010
    I was told by I can’t remember who but somebody I trusted to use type F in my Challenger so that’s been in there for years.
    • Like Like x 1
  19. notsosan
    notsosan New Member
    19
    0
    Apr 19, 2011
    Canada
    ATF in my 66
  20. bluefury361
    13,133
    9595
    Mar 9, 2011
    Alabama Gulf Coast
    I found this under the rear seat of my 67 convertible today.....
    • Like Like x 2
