joetrike13
hello everyone. im new to the forum. and i have some questions. ilene is leaking oil out of the side of the motor passenger side. Was oil and coolant mix leak. Going to work on figuring out where the leak is. was told possible head gasket which the temp never got hot. I know the motor is tired. has 89,000 miles and burns oil well was i thought till i saw a puddle under it when my fiance was driving it the other night. any help or ideals to check. i build Old VW engines. would a 360 swap be better, i have a 360 lined up if its the head gasket. id rather buy a good long block if its head gasket. i don't have the time or budget to rebuild the 318 poly as this one is gutless. which might be my fault for putting a taller tire on the rear with the 2.73 gear. but it was gutless when it had smaller tires.
