Senator Leahy
So far this is what I got, gas gauge doesn't work (new sending unit, ground strap and voltage regulator), the wiper motor makes a clicking sound when in the "ON" position (wipers work but when the switch is off they just stop), back-up lights flicker then go off, then come back on and repeat the same process, I replaced all of the bulbs in the dash, voltage regulator, and the fuses, and sometimes the dash light work, sometimes they don't, the spot for the A/C fuse in the fuse block is blown/melted out but when i put the circuit tester on it it works. Lets see...what else...replaced the bulbs in the tail lights, now one of them is out, i pulled the after-market "JC Penny" radio out because it didn't work (pretty sure someone crossed some wires), there's a black wire from behind the steering horn switch that isn't connected to anything, cant figure out what it plugs into. Some one out there please if you could help me work out a few of these things and point me in the right direction would be greatly appreciated!!!! I know a lot of this stuff is pretty vague on what is going on, I've checked for continuity to most of these things, power, burned traces, etc. but any help would be great to give me an idea on whats going on.
